Home » Support » 3D Design »
Ball joints and other moving parts
Ball joints and other moving parts [message #14151] Thu, 01 July 2010 00:30 UTC Go to next message
I'm currently working on my first 3D-printable project, which is a small (about 2.5-3" at the longest dimension) multi-part action figure. By the looks of it, it will consist of about 25 moving parts, and for most of these I intend to use WSF to make snap-in hinges and ball joints.
Most of the model is worked out barring surface detailing and a bit of hollowing to conserve materials. But I need to check on the tolerances of the material so I can make sure I've left enough clearance on the joints.
Is there enough flex in WSF to allow a ball slightly larger than the entrance hole (say, and extra 0.5-1mm) to pop in? I'd add a slot in the back of the socket to allow air to escape as the ball goes in. And does anybody know how much clearance I'd need to make around the ball to allow it to fit snugly but still move when rotated? I've seen people mention leaving 0.5mm around moving parts that will be printed in situ, but this will probably be assembled post-printing, so I'd assume the clearance wouldn't need to be quite that high.
Andy
Re: Ball joints and other moving parts [message #14168 is a reply to message #14151 ] Thu, 01 July 2010 09:54 UTC Go to previous messageGo to next message
There is plenty of flex in WSF Smile
Make sure to keep the wall thickness > 0.7mm.
Preferably double in the "working/bending" parts.
For a post-print snap joint I would not use any extra clearance.
In my experience negative spaces (socket) tend to be every so slightly smaller by 0.1-0.2mm. And positive spaces (ball) 0.1-0.2 mm bigger.
So chances are it will work as it should, if you make the ball the same size as the socket.
If you add some extra material, I would not go as high as 1 mm, that would be very tight I think. Stay under 0.5 mm perhaps.
But a lot depends on the actual design (and probably print orientation, over which we have no real control), so best is probably to test-print a few joints. Preferably with multiple orientations in one file, to make sure it works regardless of print direction.
Stijn
Re: Ball joints and other moving parts [message #14175 is a reply to message #14151 ] Thu, 01 July 2010 10:45 UTC Go to previous messageGo to next message
Thanks for the input! In case I wasn't clear, when I referred to "extra material" on the socket I was referring to making the entrance to the socket slightly narrower than the main ball and socket themselves; that way the ball pops in and the socket entrance holds it in place. But as you mentioned, I shouldn't need the diameter more than half a millimetre smaller to do the job.
I'm aware of the 0.7mm minimum, and I'm trying to keep the walls as thick as I can - although that's proving to be a challenge in some places, given the size of the figure and all the parts-inside-parts action!
I'm certainly not making my first print a simple one..! Razz
Andy
Re: Ball joints and other moving parts [message #14179 is a reply to message #14175 ] Thu, 01 July 2010 11:21 UTC Go to previous messageGo to next message
Ah sorry I missed the "entrance" part Embarassed
As long as the entrance is not "solid" but more like bendable notches, you should probably make the entrance smaller by at least 1 mm Smile
For example this design :
http://www.shapeways.com/model/35009/ball_joint_v1.html
worked except I did add a little clearance, which made the joint too loose.
Re: Ball joints and other moving parts [message #14190 is a reply to message #14179 ] Thu, 01 July 2010 13:30 UTC Go to previous messageGo to next message
Virtox: that's model is not 'public', so we can't see it.
Re: Ball joints and other moving parts [message #14192 is a reply to message #14190 ] Thu, 01 July 2010 13:37 UTC Go to previous messageGo to next message
Actually, it's not ... Confused
It says "Available to all" "Show Only"..
(i see in a different browser what you mean, weird it's shows the size and all, but no pictures...)
Flipping some options saving it works again. Let me guess, caching Wink
[Updated on: Thu, 01 July 2010 13:42 UTC]
Re: Ball joints and other moving parts [message #14193 is a reply to message #14192 ] Thu, 01 July 2010 13:39 UTC Go to previous messageGo to next message
Ok, there's something odd going on. Yes, I can access the model's page but all the images on it say 'This model is no longer publicly available' when I'm logged in. When I'm not, it's ok. I'll ask our IT guys.
[Updated on: Thu, 01 July 2010 13:40 UTC]
Re: Ball joints and other moving parts [message #14194 is a reply to message #14151 ] Thu, 01 July 2010 13:44 UTC Go to previous messageGo to next message
Seems to be working now. I know sometimes if you hit save and change pages too quick you get weird results.
Re: Ball joints and other moving parts [message #14197 is a reply to message #14179 ] Thu, 01 July 2010 13:54 UTC Go to previous messageGo to next message
Actually, while I got the "not publically available" message too, I found I could still use the 3D viewer for it, so it was still helpful. Smile
Don't you think a "solid" lip would have enough flexibility, then? Most of the balls will only be between 2 and 4mm in diameter, so I doubt I'd want more than a half millimetre reduction for the entrance lip anyway.
I love your ball joint design. If you don't mind my borrowing it, something like the socket to that could prove very useful on the larger joints, like the hips; it looks like it would have the extra benefit of reduce how much material I'd need, too.
I think I'd need to stick with a more traditional joint for the smaller knees and ankles, though.
Andy
Re: Ball joints and other moving parts [message #14199 is a reply to message #14197 ] Thu, 01 July 2010 14:06 UTC Go to previous messageGo to next message
With solid lip, you mean like pushing a bigger ball through a donut ?
If you could get it in there without breaking the WSF, it might get to loose too quickly due to wear.
Your welcome to use the ball joint design. I've thickened the whole by 0.1 mm, so it should be tighter and sturdier now.
But this design was primarily focussed on "cheapness" so for heavy duty use, the "stilt" and "lips" would need some reinforcement.
http://www.shapeways.com/model/133448/balljoint_v2.html
Attached is the STL (mm) file for reference.
You're welcome to use it, but in the case you get (filthy) rich with it, I expect to benefit also Razz
Cheers !
[Updated on: Thu, 01 July 2010 14:10 UTC]
Re: Ball joints and other moving parts [message #14203 is a reply to message #14151 ] Thu, 01 July 2010 14:41 UTC Go to previous messageGo to next message
You could always go stainless Rolling Eyes http://www.shapeways.com/forum/index.php?t=msg&goto=1170 8&S=c9d5c28bbacb1a20c7d889c4c7acab11&srch=stainless+ joint#msg_11708
Re: Ball joints and other moving parts [message #14216 is a reply to message #14199 ] Thu, 01 July 2010 17:27 UTC Go to previous messageGo to next message
virtox wrote on Thu, 01 July 2010 14:06
I suppose the doughnut analogy sort of works, yeah. The idea being that the lip has just enough give to let the ball past with a little force. Once it's on, you have to pull the pieces apart, they won't just fall off. And while I can see how it might loosen if you popped them on and off all the time, I wouldn't have thought doing it once or twice (basically to assemble the parts) would weaken it that much, if at all. I guess that's something I'll only know for sure once I get an actual printout in hand.
But I have a ton of toys with ball joints working on exactly the same principle, so I see no reason why it wouldn't work.
Youknowwho4eva wrote on Thu, 01 July 2010 14:41
I actually briefly considered steel for a few parts, but I'll probably want to dye most of them, plus I imagine the steel would get expensive very quickly.
Re: Ball joints and other moving parts [message #14217 is a reply to message #14151 ] Thu, 01 July 2010 17:36 UTC Go to previous messageGo to next message
This version would cost me $1.70 a piece but it's untested. the tested version cost $3.40. So depending on the size of your model it could get exspensive, but as long as you stick to the limits of stainless, it's not too bad. Even this one I could probably trim off another 10 cents or so.
http://www.shapeways.com/model/111362/smaller_test.html
Re: Ball joints and other moving parts [message #14220 is a reply to message #14151 ] Thu, 01 July 2010 17:53 UTC Go to previous messageGo to next message
Well, I did a really, really rough calculation based on boundary dimensions, and if I do it all in WSF, it'll probably cost me somewhere in the region of $30, though I think (and hope) I was deliberately overestimating there, since I'm removing as much interior material as I can.
Re: Ball joints and other moving parts [message #14361 is a reply to message #14151 ] Sun, 04 July 2010 21:27 UTC Go to previous message
Well, I just finished cleaning up and uploading my model, so I thought I'd post it here. I want to wait till I'm able to get a test print before I release it for sale, but I'm pleasantly surprised at the price - basic cost of the SWF is less than $19, so once I actually have some money I'll be test-printing that and possibly the Black Detail version too.
http://www.shapeways.com/model/134144/despoiler.html
Previous Topic:What is wrong with this and how can I fx it?
Next Topic:whats wrong with this WRL file
