Home » Support » 3D Applications » Mathematica supports export to .STL, .X3D, and .VRML
Mathematica supports export to .STL, .X3D, and .VRML [message #13679] Mon, 14 June 2010 22:00 UTC Go to next message
avatar wstomv  is currently offline wstomv
Mathematica version 7 (and probably older versions as well) supports export to .STL, .X3D (3.0), .VRML (2.0), and many others.
See: < http://reference.wolfram.com/mathematica/guide/3DGeometryAnd ModelingFormats.html>
Re: Mathematica supports export to .STL, .X3D, and .VRML [message #13754 is a reply to message #13679 ] Thu, 17 June 2010 09:46 UTC Go to previous messageGo to next message
Thanks wstomv! I've added your info to our list of supported applications:
http://www.shapeways.com/tutorials/supported-applications
Re: Mathematica supports export to .STL, .X3D, and .VRML [message #26014 is a reply to message #13679 ] Wed, 13 April 2011 15:02 UTC Go to previous message
Bit of a late reply but...
Does anyone know if this programme (or any other prog) will allow for the importing of X3D files and then scaling before saving again?
The reason I ask is the problem I'm having with ZBrush 4. I want to export a model in X3D with full polypaint info, but the scale is horrendous. The same model (tool) exported as an OBJ comes in at 4cm into Rhino but sent to Shapeways is then 4000 cm's !! Rhino cannot import X3D files (at least not my version).
I know someone posted a workaround here regarding adding scaling into the text file of a VRL but this would have to be different for the X3D file, right?
Glenn
Previous Topic:Something goes wrong with sketchup / meshlab / java preview
Next Topic:Missing face on "My Design" page
