Home » Community » Co-Creator Feedback » Co-Creator update
Co-Creator update [message #13545] Thu, 10 June 2010 16:03 UTC Go to next message
avatar pp  is currently offline pp
Maybe some of you already have seen it but this week we have updated and added some features to the Co-Creator platform.
Updated:
1) Possibility to create a drop-down box with predefined values to have your customers select from
2) Possibility to create radio buttons with values
3) Possibility to us multiple (up to 20!!) variables on setting up you template
We will add a short tutorial soon. In the mean time you can play around with it, for it works real easy.
cheers Peter Paul
Re: Co-Creator update [message #13616 is a reply to message #13545 ] Fri, 11 June 2010 20:03 UTC Go to previous messageGo to next message
avatar jasolo  is currently offline jasolo
I'm having problems making my first co-creator, so I'm not sure if it's my fault or because of the update. After clicking the button that activates co-creator, I see the link "+ Manage Template Details", but it doesn't expand when clicked, so I cannot introduce the parameters (although they are in the page source code). I have tried with Firefox and Explorer, and changed the availability of the model, but without success.
Re: Co-Creator update [message #13618 is a reply to message #13545 ] Fri, 11 June 2010 20:54 UTC Go to previous messageGo to next message
I have passed in on to software development to figure out what goes wrong.
I have just tested it and it works well for me on Fire Fox
I'll keep you posted.
Peter Paul
Re: Co-Creator update [message #13631 is a reply to message #13618 ] Sat, 12 June 2010 13:55 UTC Go to previous messageGo to next message
avatar ibec  is currently offline ibec
I'm having the same issues like jasolo. No matter what browser I use on my Mac, the templates don't work.
Re: Co-Creator update [message #13637 is a reply to message #13545 ] Sat, 12 June 2010 22:34 UTC Go to previous messageGo to next message
Hi
We have found the problem and working to fix it asap.
So it's not your browser it's something from our end.
If you want to you can post the model (URL) you want to work on here. We can manual fix something here until the final fix
cheers Peter Paul
Re: Co-Creator update [message #13639 is a reply to message #13637 ] Sat, 12 June 2010 22:41 UTC Go to previous messageGo to next message
The model is: http://www.shapeways.com/model/128281/wire_mesh_head_profile .html
Thanks.
Re: Co-Creator update [message #13658 is a reply to message #13639 ] Mon, 14 June 2010 09:51 UTC Go to previous messageGo to next message
It's working smooth again, thx!
Re: Co-Creator update [message #14033 is a reply to message #13545 ] Mon, 28 June 2010 04:23 UTC Go to previous messageGo to next message
avatar roofoo  is currently offline roofoo
Does shapeways mark up the price on Cocreator products? I have a ring that cost $23 for SS after my markup, but when I looked at it from a different browser, not logged in, the cost was $36! So it seems like Shapeways is taking a much larger profit for the Cocreator products.
[Updated on: Tue, 29 June 2010 17:40 UTC]
http://www.eyephoriadesign.com http://www.shapeways.com/shops/eyephoriadesign http://www.etsy.com/shop/eyephoriadesign
Re: Co-Creator update [message #14066 is a reply to message #13545 ] Tue, 29 June 2010 07:48 UTC Go to previous messageGo to next message
Hi Roofoo,
Shapeways definitely doesn't put and extra markup on any products that are on Co-Creator.
Our pricing remains as normal.
cm3 price (different per material!!) + shop owners markup= sales price
Not sure what happened with you maybe 1 time you were logged in 1 time and the other time not... maybe you had different materials selected....?
If you have some more info please let me know.
Peter Paul
Re: Co-Creator update [message #14089 is a reply to message #14066 ] Tue, 29 June 2010 17:32 UTC Go to previous messageGo to next message
It's definitely adding a higher markup than what I put in. http://www.shapeways.com/model/132452/triangle_ring.html
For stainless steel, the final cost is $14.50. However, when I log out and then load the same product page, when I select stainless steel the price jumps to $25!
And this model: http://www.shapeways.com/model/132458/wavy_ring.html
When logged in, final price for stainless is $23.00. When I log out, the price becomes $36.00!!
This seems like a major bug because this could scare away potential customers who are not logged in to the site.
[Updated on: Tue, 29 June 2010 17:38 UTC]
Re: Co-Creator update [message #14095 is a reply to message #14089 ] Tue, 29 June 2010 19:48 UTC Go to previous messageGo to next message
Here wavy ring is listed with a 36 dollars price tag, always, logged or not... maybe you are seeing pre markup price (and what you'll be charged if ordering it) when logged in?
Re: Co-Creator update [message #14096 is a reply to message #13545 ] Tue, 29 June 2010 19:51 UTC Go to previous messageGo to next message
I probably know what is going on.
The $23 will be the cost you as model owner see on the model details page and this is based on the actual volume.
The $36 is the price I see when viewing your model and is based on the Max volume as you have set it.
This means the price of the models maximum volume as set by you in the template details.
You can check by adjusting the max volume.
So it my best guess is that it's not a bug.
Please let me know if I am not right...
Re: Co-Creator update [message #14097 is a reply to message #14096 ] Tue, 29 June 2010 20:34 UTC Go to previous message
You're right, it is because I had the max volume set too high. It makes sense now. I guess I should be more accurate when estimating that. Thanks!
Previous Topic:Shipping Labels
Next Topic:Co-creator production time countdown not in working days ?
