Thanks for the post!
Although this looks new, I doubt they will be able to get a patent on it because, from what they're relieving, this is nothing new. We already use an oxygen permeable membrane to cause a liquid layer to form between the part and the oxygen permeable membrane. Also, we already control the amount of oxygen that gets to the resin by adjusting the thickness of the membrane when it is constructed. They may be doing some things that they are not revealing at this time and that may be of some novelty, but from what I can see from their current discloser there is nothing new here.
What's more is, they are not going to be able to move the part continuously as it is forms for every type of part geometry. They can for things like the Bucky ball and the Eiffel Tower, but not part geometry that has a large cross sections. The reason is, the liquid resin needs to flow into the exposure area, yet, due to hydraulic limitations cannot flow in at an accelerated rate that can keep up with a continuous Z movement. Part geometry that has a small cross section will work, but not large cross sections. This limitation can even be seen in their timelaps video of the Eiffel Tower, you can see the Z movement slow down for the areas that have a higher cross section.
One last thing I noticed is, they are not printing in a continuous analog process, they are still printing in layers and those layers can be seen in the electronmicrograph. There is no way that I can think of to do it completely analog using the current technology we have available.
One thing that they ARE doing is they are printing faster, but everyone with this type of printer, including myself, are going to make adjustments so that we can print faster too. I didn't know that could be done, and that is commendable, I highly appreciate their work here, but if they want to get an enforcible patent, they may need to get more creative in the way they are describing what they have discovered.
