Hi, does anybody know how to make a printable wireframe object in blender - i can design an object which appears as a wireconstruction when its rendered but when i export it to Accutrans i becomes solid. Hm, i have no idea at the moment how to solve this. Kind regards Simon
Hi! I've used the "Solidify selection" and/or "Solid wireframe" (both found under Mesh / Scripts) to make wireframe models. I think "Solid wireframe" is the best choice based on the fact that you get a solid when exporting to Accutrans. That script uses the polygon/face edges to make a wireframe and you can specify the thickness/radius and some detail/shape related options in the script dialog. Hope that helps
Blender has a script called "Solid Wireframe" that can do this for you. Split the 3D view and make the new area into a Scripts view, then go Scripts menu => Mesh => Solid Wireframe. It's what I used to create this model.
Hi, getting a wireframe model in blender works good with the "solid wireframe" function in the script window. But sometimes i get objects with vertices going crazy out of my original model. Anyone an idea how to get a wireframe without these vertices. Thanks Simon
