Got really stuck again.
Got really stuck again. [message #12882] Sat, 15 May 2010 12:25 UTC Go to next message
avatar gharryh  is currently offline gharryh
Hi all,
Now i got stuck again with creating a simple model.
It hasn't funny things, just plain walls with holes in it.
I create these using Microstation.
Start with a solid flat shape, punching the holes.
I then render that part to check if the holes are there.
Then i extract that part as a solid to get the correct wall thickness.
Thats all i do and even then there are many errors.
See the attached picture that Shapeways return.
Could anyone pleeease explain me in a simple language what i am doing wrong. Dont opt for buying a other drawing package be-course there is no budget for that.
harry
  • Attachment: Capture.JPG
    (Size: 159.52KB, Downloaded 192 time(s))
Re: Got really stuck again. [message #12884 is a reply to message #12882 ] Sat, 15 May 2010 14:01 UTC Go to previous messageGo to next message
what software are you using to create the model?
Aut Viam Inveniam Aut Faciam
Re: Got really stuck again. [message #12886 is a reply to message #12882 ] Sat, 15 May 2010 15:23 UTC Go to previous messageGo to next message
As i stated i am using Bently Microstation 2004 v8i
Then export it to a .wrl and with AcuuTrans3D to a dea file
Re: Got really stuck again. [message #12892 is a reply to message #12886 ] Sat, 15 May 2010 23:03 UTC Go to previous messageGo to next message
avatar akeno  is currently offline akeno
export in stl and fix in netfabb for free.
Re: Got really stuck again. [message #12913 is a reply to message #12882 ] Mon, 17 May 2010 12:39 UTC Go to previous messageGo to next message
Are you unioning them in Microstation before export? It appears you have internal meshes because the individual pieces aren't joined. They just overlap.
Re: Got really stuck again. [message #12948 is a reply to message #12882 ] Mon, 17 May 2010 19:44 UTC Go to previous messageGo to next message
OK i did some rethinking after your overlap remark.
As i produce a 3d model it doent care about over lapping but 3D printing does.
So i redrawn a part of the construction with no overlaps.
And after that i created a union of the tree parts.
http://www.shapeways.com/model/120120/dg2421_1_45_scale.html
On strange problem still occourse with microstation during unions.
If executed in a certain view it may result in a error and not in a other view.
[Updated on: Mon, 17 May 2010 19:47 UTC]
Re: Got really stuck again. [message #12951 is a reply to message #12882 ] Mon, 17 May 2010 19:55 UTC Go to previous messageGo to next message
The view thing is odd. I think you have your item set to private, as your link tells me I'm not allowed to view it.
Re: Got really stuck again. [message #12963 is a reply to message #12951 ] Tue, 18 May 2010 13:50 UTC Go to previous messageGo to next message
Its visible now
Re: Got really stuck again. [message #12967 is a reply to message #12882 ] Tue, 18 May 2010 14:22 UTC Go to previous messageGo to next message
Looks like we're making progress, do you need any more assistance at the moment, or are you moving forward?
Re: Got really stuck again. [message #12971 is a reply to message #12967 ] Tue, 18 May 2010 14:41 UTC Go to previous message
I will try to complete the model tonight. Hope that all wil got OK Rolling Eyes . Will keep you informed.
Previous Topic:Rhino question; constructing gears
Next Topic:Lightwave VRML export
