Home » Support » 3D Applications » Rhino question; constructing gears
Rhino question; constructing gears [message #12802] Thu, 13 May 2010 14:29 UTC Go to next message
avatar LatexSpikes  is currently offline LatexSpikes
I'm still learning the program, so bear with me. Smile
I'm trying to build a beveled gear. I have the surface(s) of the gear where the teeth meet, and a truncated cone with a hole in it as the base (highlighted), but I can't figure out out the get the top & bottom of the teeth. Any help would be appreciated.
http://img248.imageshack.us/img248/8840/gearj.jpg
Re: Rhino question; constructing gears [message #12803 is a reply to message #12802 ] Thu, 13 May 2010 14:36 UTC Go to previous messageGo to next message
Hi, you should be able to loft the edges.
V
www.dotsan.com
www.dotsan.com
Re: Rhino question; constructing gears [message #12806 is a reply to message #12802 ] Thu, 13 May 2010 15:01 UTC Go to previous messageGo to next message
I don't know much about rhino, but in my software I'd draw a line between the 2 ends on both top and bottom, and create a boundary surface. Join into a solid, and boolean union with the base.
Re: Rhino question; constructing gears [message #12808 is a reply to message #12803 ] Thu, 13 May 2010 15:02 UTC Go to previous messageGo to next message
Ok, I'm trying that but all it gives me is more surfaces and no solids, and I still can't BooleanUnion a tooth to the main hub. Is there a way to tell Rhino to merge all the surfaces of a tooth into one solid?
Re: Rhino question; constructing gears [message #12811 is a reply to message #12802 ] Thu, 13 May 2010 17:24 UTC Go to previous message
In my software it's called stitch and un-stitch. You could do it two ways. Easiest would be stitch and union. Sometimes in my software, it complains about it (rarely) so I have to un-stitch the face I'm attaching it to, trim the surfaces to each other, and stitch it all back together.
Previous Topic:Need help re wall thickness in Rhino
Next Topic:Got really stuck again.
