iCharge - Pocket AC charger for iPhone.
iCharge - Pocket AC charger for iPhone. [message #11780] Thu, 15 April 2010 13:26 UTC Go to next message
Hey guys,
I received today my latest design/idea for ... you gust it.. the iPhone..
First i must say ...Shapyways - You Guys Have Really Out Done Yourself This Time! ! Smile
The 3D print quality is amazing!
( still waiting for my full color Apple Apps coaster
http://www.shapeways.com/model/102905/icoasters_of_apple_app s.html )
This new design is a pocket AC charger for your iPhone.
http://www.shapeways.com/model/108197/icharge___pocket_wall_ charger_for_iphone.html
http://www.youtube.com/watch?v=O25rYIZHBTE
Where ever you are.. when ever you have low battery on your iPhone... simply pull this compact charger from your pocket , insert it to any outlet , place your iPhone or iPod Touch on top and let it charge while resting backwards on the wall.
No need to carry a bulk charger and an annoying USB cable...while outdoors.
There are 2 moving parts in this design.
The 0.6 mm gap made sure they wont fuse with the model & stay loose to swivel.
The connector holder swivel 10 degrees backwards.
index.php?t=getfile&id=3297&private=0
index.php?t=getfile&id=3298&private=0
index.php?t=getfile&id=3299&private=0
index.php?t=getfile&id=3300&private=0
index.php?t=getfile&id=3301&private=0
Once i'm done with the electronics assembly i will post some more pics.
P.S: you can see in the background the iDock for iPhone ..
http://www.shapeways.com/model/99403/idock_for_iphone.html
It's still look awesome and clean-white thanks to the fact that i coat all my 3D printed models with a fast-dry epoxy-like spray which you can find at any store for $5.
Dizingof
http://www.shapeways.com/shops/dizingof
  • Attachment: PICT0003.JPG
    (Size: 191.38KB, Downloaded 609 time(s))
  • Attachment: PICT0004.JPG
    (Size: 229.31KB, Downloaded 628 time(s))
  • Attachment: PICT0005.JPG
    (Size: 201.13KB, Downloaded 624 time(s))
  • Attachment: PICT0007.JPG
    (Size: 179.07KB, Downloaded 613 time(s))
  • Attachment: PICT0010.JPG
    (Size: 231.98KB, Downloaded 627 time(s))
http://www.3Dizingof.com
Re: iCharge - Pocket AC charger for iPhone. [message #11826 is a reply to message #11780 ] Sat, 17 April 2010 15:47 UTC Go to previous messageGo to next message
Hi All,
I'm very excited to show you the final result for the iCharge - a pocket wall charger for my iPhone - iPod Touch.
I assembled the 2 electronics boards inside , welded the connector and the whole thing is closed tightly in its 3D printed casing.
This is how this NEW unseen before product looks like:
index.php?t=getfile&id=3322&private=0
index.php?t=getfile&id=3323&private=0
index.php?t=getfile&id=3324&private=0
index.php?t=getfile&id=3325&private=0
What you guys think?
Has anyone had experience in registering a design in the EU / USA ? i might need to look into this ..
http://www.shapeways.com/model/108197/icharge___pocket_charg er_for_iphone.html
Dizingof
    (Size: 244.29KB, Downloaded 539 time(s))
  • Attachment: PICT0006.JPG
    (Size: 244.11KB, Downloaded 531 time(s))
    (Size: 244.56KB, Downloaded 528 time(s))
  • Attachment: PICT0009.JPG
    (Size: 243.48KB, Downloaded 525 time(s))
Re: iCharge - Pocket AC charger for iPhone. [message #11829 is a reply to message #11826 ] Sat, 17 April 2010 18:21 UTC Go to previous messageGo to next message
avatar svofski  is currently offline svofski
It's an interesting design and congrats with the nice looking results. But I don't have a single socket at my home, or at my work, or anywhere I know actually, that could accept this plug without some extra adapter. Most power sockets here are sunk by approx 2cm into the wall and that would make them unreachable by the shortie pins of your adapter.
Something not unlike this one, except for the pin in the middle.
http://farm4.static.flickr.com/3400/3244616201_e336148a65.jp g
Re: iCharge - Pocket AC charger for iPhone. [message #11830 is a reply to message #11829 ] Sat, 17 April 2010 18:44 UTC Go to previous messageGo to next message
svofski wrote on Sat, 17 April 2010 18:21
well i designed it for my country's socket Smile
http://www.firstline.co.il/shoeLargePic.asp?pic=680-861_big. JPG
I know different EU countries have that socket you showed and of course it wont work with this design.
But... perhaps if i were to design 2 horizontal power rods rather then vertical as it is right now that would enable larger rods that can reach the inside of your socket.
something like in my first concept:
http://www.youtube.com/watch?v=PW6H7n-9r60
Re: iCharge - Pocket AC charger for iPhone. [message #11831 is a reply to message #11830 ] Sat, 17 April 2010 18:50 UTC Go to previous messageGo to next message
Pin lenghts problems aside, I'd prefer a vertical design, indeed. Mostly because it wouldn't make me remove plugs from all neighbouring sockets Wink
Re: iCharge - Pocket AC charger for iPhone. [message #11836 is a reply to message #11831 ] Sat, 17 April 2010 19:41 UTC Go to previous messageGo to next message
svofski wrote on Sat, 17 April 2010 18:50
I didnt quite catch that
What i meant was the rods will each swivel horizontally, this way any EU socket will fit this charger because of the larger rods.
I will look into it.
Thanks for that input Wink
Re: iCharge - Pocket AC charger for iPhone. [message #11848 is a reply to message #11836 ] Sun, 18 April 2010 04:27 UTC Go to previous messageGo to next message
avatar akeno  is currently offline akeno
Cool design and congrats on it! -- but the USA has a wall charger about 1x1x1 inch all around that fits in a socket and is easily if not more portable then this, I can't see myself using it Sad
Re: iCharge - Pocket AC charger for iPhone. [message #11849 is a reply to message #11848 ] Sun, 18 April 2010 05:04 UTC Go to previous messageGo to next message
akeno wrote on Sun, 18 April 2010 04:27
A 1x1x1 inch charger is a bit thick to carry in your pocket.. plus you do need to carry a USB cable as well.
At the moment this prototype is 20mm thick , with 2 mm wall thickness - i believe i can reduce it even more.
It's one unit. compact and fold-able. ready to charge your iphone where ever you are within city limits.
BTW, i'm amazed how small the electronics boards are..
it outputs regulated 5V 800ma (very impressive power) and not getting hot non what so ever. very cool!
If i find an even smaller board i would go with my first design instantly (see youtube link above) - it received nice reviews on 2 iphone websites (of course i plugged shapeways.com as always.. letting every one know about this great service)
Thanks for your input Wink
Re: iCharge - Pocket AC charger for iPhone. [message #11901 is a reply to message #11780 ] Mon, 19 April 2010 18:38 UTC Go to previous messageGo to next message
Could you tell me what the $5 epoxy-like spray is that you use on your models?
Re: iCharge - Pocket AC charger for iPhone. [message #11902 is a reply to message #11901 ] Mon, 19 April 2010 19:04 UTC Go to previous messageGo to next message
lensman wrote on Mon, 19 April 2010 18:38
well i dont know if this brand is sold where you are , the label says "weekend spray" - KRYLON by sherwin williams USA.
something like this:
http://www.krylon.com/products/crystal_clear_acrylic/
or better :
http://www.krylon.com/products/triplethick_crystal_clear_gla ze/
Re: iCharge - Pocket AC charger for iPhone. [message #11965 is a reply to message #11780 ] Wed, 21 April 2010 14:42 UTC Go to previous messageGo to next message
My model iCharge was showcased today at an iphone website , members asking where can they buy it.. Cool
http://www.iphoneil.net/?p=39204#more-39204
Re: iCharge - Pocket AC charger for iPhone. [message #11967 is a reply to message #11780 ] Wed, 21 April 2010 14:49 UTC Go to previous messageGo to next message
When can we see an American version? Seeing my car charger broke the other day Mad I considered taking it apart to make something like this specifically for my car. I have 2 outlets. One on the dash where I have my radar detector, and one in my center console, which likes to break the cables if you close it wrong on the cable. I just now got an idea, I wonder how feasible it would be...
Re: iCharge - Pocket AC charger for iPhone. [message #11969 is a reply to message #11967 ] Wed, 21 April 2010 15:21 UTC Go to previous message
Youknowwho4eva wrote on Wed, 21 April 2010 14:49
Oh.. i wish there was a way for a joint-partnership with shapeways for mass producing of an idea and marketing it..
Right now all i can sell you is the plastic casing Rolling Eyes
Or if you are a DIY... perhaps also the electronics boards and assembly instructions .. but that's not a feasible method , i tried it with my iSolar Pad for iPhone...
http://www.shapeways.com/model/103464/isolar_pad_for_iphone. html
It was too expensive for DIY's.
BTW people where is your rating on the iCharge? i'm addicted to the 5 stars Razz
[Updated on: Wed, 21 April 2010 15:22 UTC]
Previous Topic:3D stainless ball and socket joint
Next Topic:Gerardo's Cube by OSKAR
