| Tagging broken? [message #11565] Fri, 09 April 2010 14:59 UTC |
Put up my latest models for the Co-Creator contest and cant tag them as "co-design". Did notice that you can now save changes when you change the mark-up. So I'm guessing that was adjusted recently?
| Re: Tagging broken? [message #11574 is a reply to message #11565 ] Fri, 09 April 2010 16:31 UTC |
You can tag by adding "co-design" to the keywords I believe.
However, the search is not compatible with the "-" it seems to search for co and/or design.
| Re: Tagging broken? [message #11579 is a reply to message #11565 ] Fri, 09 April 2010 16:43 UTC |
Yea, I've tagged some models already with co-design. But now tags are not sticking. I just did a test with "test" as the tag. Hit save, refresh the page, and it disappears.
| Re: Tagging broken? [message #11587 is a reply to message #11579 ] Fri, 09 April 2010 17:00 UTC |
It's that darn LHC I tell ya ! Black holes appearing everywhere, even sucking the information out of the internet !
The markup-change-only-save-thingy was indeed fixed, saw some post somewhere.
| Re: Tagging broken? [message #11590 is a reply to message #11565 ] Fri, 09 April 2010 17:02 UTC |
Didn't the LHC break itself from the future?
| Re: Tagging broken? [message #11593 is a reply to message #11565 ] Fri, 09 April 2010 17:34 UTC |
Some say so, others say it was a saboteur from the future, searching for his baguette.
But as far as I know, it is happily running at the moment.
| Re: Tagging broken? [message #11666 is a reply to message #11579 ] Sun, 11 April 2010 11:33 UTC |
| Youknowwho4eva wrote on Fri, 09 April 2010 16:43 | Yea, I've tagged some models already with co-design. But now tags are not sticking. I just did a test with "test" as the tag. Hit save, refresh the page, and it disappears.
I see this too.
-Bathsheba
http://bathsheba.com
| Re: Tagging broken? [message #11667 is a reply to message #11565 ] Sun, 11 April 2010 11:48 UTC |
Same here.
Tagging updates don't save,
It says it saved successfully, but it doesn't.
| Re: Tagging broken? [message #11702 is a reply to message #11667 ] Mon, 12 April 2010 11:25 UTC |
It indeed seems tagging is broken.
Until we have this resolved you can use a work-around however. When you upload a new model you can also give tags, this still works.
I apologise for the inconvenience and the fact that we apparently did not spot this when creating the competition
| Re: Tagging broken? [message #11715 is a reply to message #11704 ] Mon, 12 April 2010 15:40 UTC |
You can also send me the names or URL's or id's or all of the models with the tags for the competition and I will make sure it's added.
sorry for the inconvenience
Peter Paul
| Re: Tagging broken? [message #11734 is a reply to message #11718 ] Tue, 13 April 2010 09:32 UTC |
Great news! Tagging has been fixed and should now function properly again.
| Re: Tagging broken? [message #12379 is a reply to message #11715 ] Sat, 01 May 2010 17:51 UTC |
Well, Peter, since you work here and seem to be involved in the contest part of things can you answer me these questions that have been frustratimg me greatly:
Nowhere on this site is it explained how a contest entrant can upload his/her model template and in what format, etc. Also, am I to understand that we simply upload as a normal co-creator piece (with necessary tags) which would then let everyone see the contest entry before it's closed?
My entry needs buyer input more than just adding some text to the model; it is more like the earrings that you feature where the buyer has to draw on the template.
G
