Home » Support » 3D Applications » Change model thickness intelligently
icon2.gif  Change model thickness intelligently [message #11314] Thu, 01 April 2010 12:20 UTC Go to next message
avatar mimekunst  is currently offline mimekunst
My model's wall thickness is below 3mm on some parts. How do I increase wall thickness only on those parts which are below? Using which tool?
If there is none, how do I generally increase wall thickness?
Best regards
mimearts
[Updated on: Thu, 01 April 2010 12:42 UTC]
Interessen: Bahn, Humor und Outdoor
http://www.mimekunst.com
Re: Change model thickness intelligently [message #11316 is a reply to message #11314 ] Thu, 01 April 2010 12:52 UTC Go to previous messageGo to next message
avatar Schorhr  is currently offline Schorhr
you should post a sample picture and state what programm you are using.
On some occasions, and depending on the material, even smaller details may print, but it is a risk. I have seen both cases: Sandstone figure with 2mm arms, and other material meeting the wall thickness requirements with broken parts.
Re: Change model thickness intelligently [message #11317 is a reply to message #11316 ] Thu, 01 April 2010 12:54 UTC Go to previous messageGo to next message
You should answer my question.
Re: Change model thickness intelligently [message #11320 is a reply to message #11314 ] Thu, 01 April 2010 13:28 UTC Go to previous messageGo to next message
I do not know of any automatic tools, your best bet is probably to use blender with the wall thickness script by Eric Finley :
http://www.shapeways.com/forum/index.php?t=msg&goto=8790
Kind regards,
Stijn
[Updated on: Thu, 01 April 2010 13:28 UTC]
Re: Change model thickness intelligently [message #11401 is a reply to message #11314 ] Sat, 03 April 2010 20:35 UTC Go to previous messageGo to next message
You should use the wall thickening tool. Smile
Many programs have a tool that can move a face along it's normal (perpendicular to the surface). Apply that to all the faces at once and you get thicker walls.
Re: Change model thickness intelligently [message #11412 is a reply to message #11401 ] Sun, 04 April 2010 02:40 UTC Go to previous message
E.g. in Blender, use Sculpt mode and the Layer tool.
Previous Topic:Scaling if you're using Wings3D
Next Topic:Help. Please suggest good beginner's software.
