blender and cm centiemeters
blender and cm centiemeters [message #641] Tue, 05 August 2008 21:07 UTC Go to next message
avatar janis  is currently offline janis
uu.. how do i see the size of objects?
i'm every new to blender.. but if i wanna make hole of 0,8cm how do i do this..
graag antwoord ook in het Nederlands voor het geval ik het engels niet begrijp Smile..
Re: blender and cm centiemeters [message #645 is a reply to message #641 ] Wed, 06 August 2008 00:24 UTC Go to previous messageGo to next message
avatar tempusr3194_9e838cda5e63  is currently offline tempusr3194_9e838cda5e63
There are no units in Blender.
Typically for Shapeways works, I do the the modelling with 1 blender unit = 1 cm, that works well.
Then I scale the objects by 0.01 to be able to feed an .STL file in meters.
Easy to do with precision in Blender :
just select you objects, then type 'S' then '0.01' then enter.
PS: I just saw that the upload page now allow to select meters or millimeters as units, so you may get away by using 1 blender unit = 1 millimeter, without the need for rescale.
PPS: if you question is how to see the units in Blender :
Type 'N' when mouse is over a 3D window : a little popup will appear, look for the DimX DimY DimZ values. And use the grid with visual reference too.
I often create a simple plane in A4 dimensions, to have a rough size reference aside my 3D scene.
[Updated on: Wed, 06 August 2008 00:28 UTC]
Re: blender and cm centiemeters [message #654 is a reply to message #645 ] Wed, 06 August 2008 07:08 UTC Go to previous messageGo to next message
thx
i type s and just put 1 and hit enter..
next i type n i get Transfrom properties
scalex,y,z : -2.062
dimx,y,z: 4.124
what does this say these values?
Re: blender and cm centiemeters [message #732 is a reply to message #654 ] Fri, 08 August 2008 00:56 UTC Go to previous messageGo to next message
dimx,y,z: 4.124 means that your object is a bit more that 4 units in width, length, height.
Shapeways now allows to select if your units are millimeters or meters or inches.
Re: blender and cm centiemeters [message #752 is a reply to message #732 ] Fri, 08 August 2008 14:37 UTC Go to previous message
oke i understand now.. i just use the dim for my 8mm
Previous Topic:Weird Rendering
Next Topic:Part 3: Configurations & Modular Design
