Interpenetration?
Interpenetration? [message #11174] Sat, 27 March 2010 23:21 UTC Go to next message
avatar zsimpson  is currently offline zsimpson
Hi, I'm thinking about algorithmically generating some shapes. I looked at the tutorials about generating water-tight meshes which makes perfect sense. However, what wasn't clear from these tutorials is if multiple water-tight volumes are allowed to inter-penetrate one another or if I have to create a single water-tight hull.
Zack
Re: Interpenetration? [message #11176 is a reply to message #11174 ] Sun, 28 March 2010 00:19 UTC Go to previous messageGo to next message
avatar Schorhr  is currently offline Schorhr
http://www.shapeways.com/tutorials/reducing_costs_for_overla pping_meshes
"...placing one cube just slightly inside another one:"
"This will print out just fine, but there’s a catch: the total volume is calculated ..."
So it should be okey?
Re: Interpenetration? [message #11185 is a reply to message #11176 ] Sun, 28 March 2010 15:39 UTC Go to previous messageGo to next message
Thanks for the link!
Make sense that the intersection volume would be calculated for estimates, but seems like one could trivially measure the actual amount of material used by simply weighing it after printing and then charge based on that actual amount. Since this will always be less than the estimate, no one will complain when it turns out to be cheaper than the estimate.
Zack
Re: Interpenetration? [message #11187 is a reply to message #11185 ] Sun, 28 March 2010 16:55 UTC Go to previous message
True, but it would turn calculating prices into a chaos of uncertain guesses and coupons, as the initial payment is in advance Smile
Previous Topic:videoBOT
Next Topic:Uploaded models not showing up in 3D view
