Home »  » 3D Applications » Assembly STL Files in SolidWorks 2010
Assembly STL Files in SolidWorks 2010 [message #11134] Fri, 26 March 2010 17:43 UTC Go to next message
avatar pirsquared  is currently offline pirsquared
Hello everyone,
I am trying to upload an assembly of parts to Shapeways, but when I save the assembly as an STL file, SolidWorks splits the assembly into individual components and saves each as its own STL file.
Could someone please explain how to upload an assembly to Shapeways from SolidWorks?
Thanks.
-Eitan
Re: Assembly STL Files in SolidWorks 2010 [message #11159 is a reply to message #11134 ] Sat, 27 March 2010 13:31 UTC Go to previous messageGo to next message
I dont have SolidWorks, but I use Solid Edge (almost the same thing) and when you save an assembly as an STL or JT, you need to Save>options>single file> then save the file.
Something to watch out for: in SolidEdge, if i save an assembly with parts that are colliding, it saves the STL with the overlapping mesh, which can NOT be printed. so try to make sure that your parts are assembled realistically.
eh, hope that makes sense.
Good luck!
________________
Check out my shop @ http://www.shapeways.com/shops/excitementproductions
Aut Viam Inveniam Aut Faciam
Re: Assembly STL Files in SolidWorks 2010 [message #11162 is a reply to message #11159 ] Sat, 27 March 2010 14:32 UTC Go to previous messageGo to next message
It worked! Thank you!
-Eitan
Re: Assembly STL Files in SolidWorks 2010 [message #11163 is a reply to message #11162 ] Sat, 27 March 2010 18:57 UTC Go to previous messageGo to next message
No problem.
I wish I had a copy of SolidWorks, i liked it a lot better than SolidEdge...
But my student copy wont work on Windows 7, so I guess Im out of luck for now.
Good luck!
___________
Re: Assembly STL Files in SolidWorks 2010 [message #54014 is a reply to message #11163 ] Fri, 14 September 2012 00:28 UTC Go to previous messageGo to next message
avatar craniumtrain  is currently offline craniumtrain
I am using solidworks 2004. I am unable to find the option to save an STL as a single file. Also unable to save assembly as a part without it loosing the solid info and turning into a collection of surfaces
Re: Assembly STL Files in SolidWorks 2010 [message #54015 is a reply to message #54014 ] Fri, 14 September 2012 00:35 UTC Go to previous messageGo to next message
You might want to get a new version of SolidWorks. How are you still using 2004? I'm on 2012.
-Eitan
Re: Assembly STL Files in SolidWorks 2010 [message #54466 is a reply to message #54015 ] Mon, 24 September 2012 22:16 UTC Go to previous messageGo to next message
Do a "Save As" for your assembly file and pick 'Part' (.sldprt) from the "Save As Type" menu. This saves your assembly as one single part. Open up this part file and save it as a .STL - you should get a single STL file that way.
I merge all the individual pieces into one solid part before creating the STL file with the "Combine" command (under Insert-Features-Combine in the top menu); I think Shapeways' software will merge multiple STL bodies into one body when you upload it, but why take chances?
Re: Assembly STL Files in SolidWorks 2010 [message #54467 is a reply to message #54466 ] Mon, 24 September 2012 22:23 UTC Go to previous message
But if you merge the parts into a single body using a Combine feature, then you will no longer have an assembly of STL files. You will have one part.
I think this question was answered in the second post (more than 2 and a half years ago!). Let's not belabor the point.
-Eitan
Previous Topic:Upload error WRL file
Next Topic:Kickstarter Friendly CAD Licensing
