Looking for someone to assist at this stage to see if my project is worth designing/considering. I wish to have made a 12mm wide conveyor truss, complete with supports for 6mm walkways, both sides, which will be integrated with metal etched walkways and handrails. Not sure if this is feasible due to the small size. Let me know your thoughts.
If you want to print it in steel, you'd have to consider that the wall or wire thickness would have to be at least 1mm, so it would help to see a picture. Or in other words, being N-scale, if the thinnest real life beam is fine with being at least 160mm thick, or you don't mind it being thicker then the actual real life model, it can be done.
Do I understand it correctly that it is several hundred meters long, and you want to print it as 12mm? I'm afraid printing steel, you won't fit that amount of details into that scale. Or do you want that center frame-work as seen in the second picture being 12mm wide and 6mm thick? That is very possible, although the members would have to be thicker than in the real life example
