Open the file in Netfabb
Click Repair. You have 28 shells
Hover over the icons at the top, Pick Select shells - pick the model, it will turn green.
Pick the icon 'Delete selected triangles' or just press delete on your keyboard.
You are left with 23 Shells.
Go to edit - Undo repairs - click Yes.
I did this so you can check inside the model.
Do the same repair sequence again, once the main shell is selected. Go to edit - toggle selection. the main shell will turn blue.
You now have the other 23 shells selected. Delete them. You now have only one shell.
Apply repair - Remove old part
Go to Part - Export Part - as Stl.
The model is still a mess inside. Shapeways ignores all of the internal geometry. In 3D printing only the outside face/shell is wanted.
