| extremely large size model? [message #10520] Sun, 07 March 2010 00:32 UTC |
hello, in my software the model has 2cm, but when i upload him, the size goes to 2200cm O_o, someone can fix this error?
I always send models to shapeways, this nevers happend
| Re: extremely large size model? [message #10521 is a reply to message #10520 ] Sun, 07 March 2010 00:38 UTC |
Did you use vrml as the upload format ? Apparently this is always defined in meters, regardless of what definition used in the 3d app.
I work in mm but before export to vrml I scale the object to 0.1% and then it works.
On the other hand, there seem to be some upload issue this weekend, perhaps this is related.
BTW there is a measure tool in the max utilities that will show the dimension of your object.
There is also a maxscript for shapeways that will do this and lots more :
http://www.shapeways.com/forum/index.php?t=msg&th=714&am p;start=0
[Updated on: Sun, 07 March 2010 00:45 UTC] - Artist / Engineer / Designer / Shopowner / Volunteer / Moderator -
