The two blanks on the left were the first ones I ordered. Unfortunately they had 7mm inside diameter holes instead of 8mm which
is required for the (obsolete) Metallo pen kit. I will try various things to get them smooth and color enhanced. They have more
frostiness than the new batch of four I received today on the right. I have plenty of Metallo kits for demo units but eventually I will
need to migrate to other kits.
The first of the new batch has pink and black colors swapped and the red changed to orange. The second with the gears has
the same outside diameter as all the others but the main core is thinner to give the gears an embossed texture. The third puzzle
piece blank has some thin gaps which match up to miniscule gaps in the design file so a different type of model construction is
needed to eliminate them. If desired those small gaps located around each of the puzzle pieces could make it look like pieces
were inlayed separately by gluing into place. The last blank with long color wedges also suffers from the gaps but they are less
noticeable for some reason..
I don't want to coat these with CA glue or lacquer if it can be avoided. I'm hoping that a light polish and buffing will remove the
frostiness and reveal nicer colors. I saw a recommendation in another thread for using isopropyl to remove frostiness so I might
also try that. I have a jug of 99.999% pure isopropyl so using that might be more interesting than the standard drug store dilution.
edit
I just checked to see if the 8mm brass tubes would fit into the new tubes. I managed to nail the fit perfectly with just a bit of
friction. These tubes are also very round and exceptionally straight. They don't seem to have any of the warping issues that
other people have experienced, probably because they are small and compact? I'm very excited to see this color process hit the
scene. It's definitely a needed development for more interesting and useful pen bodies having both color and physical relief.
