Regarding the surface orientation.
Upon loading the original STL file into Netfabb, I get
Surface is closed: No
Surface is orientable:Yes
(and a lot of holes and shells)
Then I repair the file, and the result is
Surface is closed: Yes
Surface is orientable: No
(and no more holes and 1 shell only, but a lot of flipped triangles/invalid orientations)
Then go to Meshlab, and still find a bunch of non manifold vertices, so repair those.
After saving, check again in Netfabb (and Meshlab) if all is fine indeed.
Netfabb still reporting the invalid orientation, but the surface is still closed.
I did cleanup in Meshlab on zero size faces and did a normalise vertices, but still the same Shapeways error on not manifold...
And yes I'm using the latest file
I'm now trying to fix as much as I can in the source file, but with a few hundred issues, that is no fun.
Robert
