Inventing the Wheel...
icon5.gif  Inventing the Wheel... [message #10295] Sun, 28 February 2010 18:11 UTC Go to next message
Shapeways Crew
Hi all,
I have a stupid question Embarassed , so I try to make it short: is the invention of the wheel useful in a world where all is in White Strong and Flexible?
In order to reduce friction I wanted to add a wheel in one of my design (it's for the spring of my Zen Box for those who are following this adventure Smile)
But after thinking a while (one should never think Sad), I was wondering if it was really more efficient than having the axis of the wheel in direct contact with the "ground", even if it does not turn.
This is because both the axis and the wheel will be in WSF so the friction is still WSF against WSF, I just displace the point of friction.
See this drawing:
index.php?t=getfile&id=2817&private=0
What do you think?
  • Attachment: Wheel.jpg
    (Size: 30.73KB, Downloaded 384 time(s))
Re: Inventing the Wheel... [message #10296 is a reply to message #10295 ] Sun, 28 February 2010 18:17 UTC Go to previous messageGo to next message
avatar Eeppium  is currently offline Eeppium
Hi
I think it would work fine without the wheel. much simpler that way with less moving parts.
you could add a steering rail, for the axis to follow as it moves along the surface.
Re: Inventing the Wheel... [message #10305 is a reply to message #10295 ] Mon, 01 March 2010 08:57 UTC Go to previous messageGo to next message
I don't think the friction would much different in those cases.
If you were to add bearings, you could reduce friction.
But I agree with Eeppium, it seems a bit like overcomplicating things Wink
Just a thought : how about using magnets to push things apart ?
Re: Inventing the Wheel... [message #10307 is a reply to message #10295 ] Mon, 01 March 2010 13:28 UTC Go to previous messageGo to next message
Any wheel spinning on a axis would have friction. Be interesting to find a lube that works for wsf.
Re: Inventing the Wheel... [message #10325 is a reply to message #10307 ] Mon, 01 March 2010 19:20 UTC Go to previous messageGo to next message
I would vote to go without a wheel. Like was said before, its simpler. And I also agree that the friction in this case, probably wouldnt be a whole lot different, if not less without a wheel. (WSF is porous, lots of friction, more moving parts=more friction=more wear)
In a small model like this, i think that most similar parts (in retail) probably would NOT have a wheel, mostly because its cheaper, but I really dont see it as a necessary addition. Keep it simple.
Thats my mostly repetitive 2 cents. Razz
Aut Viam Inveniam Aut Faciam
Re: Inventing the Wheel... [message #10330 is a reply to message #10325 ] Mon, 01 March 2010 21:15 UTC Go to previous messageGo to next message
Shapeways Crew
Thank you very much for your replies. I will follow your advice and keep it simple.
Actually, apart from the magnets (probably not easy to realize), the only thing that could be better than the axis in direct contact with the surface would be the bearing (because in this case I think that all is rolling without slipping so there is no friction, or more exactly the friction helps the different parts rolling).
But I have little room in this design, so the choice is easy to do Smile
Magic
PS: I was reading my first post and the expression I used - "a world where all is in White Strong and Flexible" - made me dream... Say the mankind, instead of inventing fire, would have invented first the 3D printing in White Strong and Flexible, how would our world be today? The wheels would probably be triangular (with a vertex pointing downward) because they do not need to roll: the road, the wheels and the axes of the wheels are in WSF, so the friction would be the same... Hmmm. Interesting. Or may be not. Very Happy
Re: Inventing the Wheel... [message #10333 is a reply to message #10295 ] Mon, 01 March 2010 22:00 UTC Go to previous messageGo to next message
hmmm
in larger cases, even if the road was WSF and the wheel was WSF, a wheel would be better because there is still a huge amount of fricion between 2 points. with a triangular wheel, you would (more than likely) wear that triangle out very quickly. Whereas a wheel, distributes (if thats the right word..) the friction over a different area.
I feel like i should know the technical terms that make a wheel better than a stationary bearing, but i dont right now. But unless you have a very low friction surface like snow or ice, a wheel will work far better than a stationary bearing.
Re: Inventing the Wheel... [message #10336 is a reply to message #10333 ] Tue, 02 March 2010 00:15 UTC Go to previous messageGo to next message
I'm not sure about the friction, but the wheel has a big advantage as far as rolling over small items and surface defects. A sliding axle will be stopped by bumps and grooves or carpeting, but the wheel rolls onward.
Re: Inventing the Wheel... [message #10400 is a reply to message #10295 ] Wed, 03 March 2010 16:45 UTC Go to previous messageGo to next message
For the magnet I meant using the repelling power to give the initial "umph" to push it open. I assumed this part of your spring-slide-thingy.?
Just two (or four on the count of 2 hinges in the zen case) "sockets" into which you glue the magnets.
Anyway not sure I can follow the whole bearing story.
But just like in a planetary gears system, all things roll instead of slide I would think. Too bad it is not printable at this size yet..
But it is an interesting thought for the (near) future... One could design more and more complex systems which would not require manual assembly. Just because we can !
But in any case with a name like "zen" overcomplicating seems out indeed Wink
Re: Inventing the Wheel... [message #10414 is a reply to message #10400 ] Wed, 03 March 2010 21:45 UTC Go to previous message
Shapeways Crew
Ah OK. I though you wanted to use magnets to reduce the friction. I better understand now.
For the bearing I think that the spheres are rolling without slipping (so they are rolling on themselves but also moving around the axis). As long as WSF do not slip against WSF I guess there should be no friction issue. It is as if you put a cylinder on a table (so that it can roll), a book on the cylinder and you move the book relatively to the table: even if the cylinder has a lot of friction (that is: it cannot slip on the table but just roll and it cannot slip on the book either), the book can move freely relatively to the table (in one direction though).
Rawkstar320 and Gibell: you are right except if the Wheel is not a rolling wheel but a non-moving wheel (our ancestors would have certainly invented the wheel this way, since making the wheel roll would have just displaced the friction problem to the axis) Smile
[Updated on: Wed, 03 March 2010 21:45 UTC]
Previous Topic:Can't find Manifold Error
Next Topic:Problems w/upload Overlapping Triangles
