hypernurbs
Discussion in 'Software and Applications' started by swellguy3, Feb 18, 2010.
  1. swellguy3
    swellguy3 Member
    Does having fewer polygons lower cost...if so, does using a hypernurbs object to smooth have any bearing on this...
    Thanks G
  2. dadrummond
    dadrummond Member
    No, cost is based on volume (see the Materials page and note that all prices are per-cubic-cm, sometimes plus a fixed startup cost).
    SW doesn't accept anything over 500,000 triangles, and you can't make a 2-manifold (printable) object with fewer than four triangles, so those are the only polygon-related constraints you need to worry about.
