Hi Everyone,
It is with great excitement that we can now offer our community Full Color Plastic. The material has a similar color range to Full Color Sandstone (note: FCP's colors are CMY & White, no true black, which Sandstone has) with a durability more comparable to our Strong and Flexible Families.
We are doing a Pilot with this material to start, to better understand its applications and see how the community engages with it. The initial designers in the pilot have been notified and will be able to start printing tomorrow.
We want you all to be involved, but signups for this portion of the pilot have closed.
The Materials Page will go live with our weekly release later today, but here's a sneak peak at the design guidelines:
Max bounding box 150 x 150 x 150 mm
Min bounding box X + Y + Z ≥ 10 mm
Min supported wall thickness 0.7 mm thick
Min unsupported wall thickness 0.7 mm thick
Min supported wires 0.8 mm thick
Min unsupported wires 1.6 mm thick
Min embossed detail 0.2 mm high & wide
Min engraved detail 0.2 mm high & wide
Min escape holes 4.0 mm diameter for one escape hole
2.0 mm diameter when there are two or more escape holes
Clearance .5mm
Interlocking and enclosed parts? Yes
Multiple parts per model file? No
Does this material add to your shop? What will it now enable you to create?
