Home » Support » 3D Applications » Export from trueSpace
icon5.gif  Export from trueSpace [message #497] Sat, 02 August 2008 01:12 UTC Go to next message
avatar lunadude  is currently offline lunadude
I have trueSpace 6.6 and 7.6, and Deep Exploration 3.5. All can export .STL format models.
I've tried uploading the same model, exported from each of these apps. No dice.
I'm not sure if the issue is with a corrupt format, or a damaged/too thin model. Will have to try something else to verify.
Anyways, the model export matrix on http://www.shapeways.com/tutorials/supported-applications, claims that trueSpace is supported, with a Collada export that is "native". I don't see a Collada export option in either versions of trueSpace.
What am I missing?
Re: Export from trueSpace [message #556 is a reply to message #497 ] Mon, 04 August 2008 07:50 UTC Go to previous messageGo to next message
Hi lunadude,
the problem is probably with the size of your object - our STL importer currently interprets 1 STL unit as 1 meter (which is a bit non-standard - we'll fix that in the next release). Scaling everything down by a factor of 100 should solve the issue.
Re: Export from trueSpace [message #571 is a reply to message #556 ] Mon, 04 August 2008 13:17 UTC Go to previous messageGo to next message
Ok, so it may be a "units" issue.
Any idea on the formats question?
Re: Export from trueSpace [message #602 is a reply to message #571 ] Tue, 05 August 2008 06:27 UTC Go to previous messageGo to next message
lunadude wrote on Mon, 04 August 2008 09:17
Hmm no - I picked that up from their on-line documentation somewhere. Looks like I'll have to re-do my homework Wink
Re: Export from trueSpace [message #1354 is a reply to message #602 ] Thu, 18 September 2008 11:58 UTC Go to previous message
Lunadude,
I don't have trueSpace running here myself so I cannot check, but I see announcements everywhere that Collada export should have been added in 7.5.. Maybe it's tucked away somewhere you didn't look yet?
About those STL files, did you succeed in getting them uploaded? If not, could you mail them to bart(at)shapeways(dot)com so I can check them out? I have a few other ideas that I'd like to try.
Previous Topic:Game model
Next Topic:3D Print Design Programs
