Mesh / Honeycomb Effect
Mesh / Honeycomb Effect [message #93805] Sat, 12 July 2014 15:53 UTC Go to next message
avatar EdChamberlain  is currently offline EdChamberlain
I see so many models that have either a mesh sir of effect or a honeycomb effect on the surface but i have no idea how they do it! i was hoping to reduce the price of some of my models by using these holes. If anyone has a suggestion on how to create them i would be very appreciative !
Ed.
E.g.
https://www.shapeways.com/model/1688324/quadcopter-frame-v-2 -new.html?modelId=1688324&materialId=6
https://www.shapeways.com/model/1398380/bowtie-round-alumo.h tml?modelId=1398380&materialId=66
Re: Mesh / Honeycomb Effect [message #93810 is a reply to message #93805 ] Sat, 12 July 2014 19:07 UTC Go to previous messageGo to next message
A lot of this depends upon what tool you are using and/or what tools you have access to.
At times, I have made models out of many (many) tiny segments and then welded them all together, at other times, I've done the exterior shell, then created a specialized part and subtracted it FROM the main shell. Both methods are viable.. it depends on the complexity you are after versus the tools you have available.
index.php?t=getfile&id=64844&private=0
  • Attachment: Subtract.jpg
    (Size: 38.04KB, Downloaded 164 time(s))
[Updated on: Sat, 12 July 2014 19:24 UTC]
Re: Mesh / Honeycomb Effect [message #93865 is a reply to message #93810 ] Sun, 13 July 2014 22:11 UTC Go to previous messageGo to next message
I've been using solidworks now for over two years and usually things like this are fairly straightforward and logical but this seems to be proving a problem. I understand the various way of creating the holes / removing the holes and the way you're image shows works perfectly on flat surfaces. The problem I am having however is that the surfaces I have created are far too complex for the methods you described.
Ill attach this link to another thread I found after posting this and have just commented on. I feel this thread would be a good place to continue the discussion as it is much more in depth.
https://www.shapeways.com/forum/index.php?t=msg&th=19875 &start=0&
Ed.
Re: Mesh / Honeycomb Effect [message #93869 is a reply to message #93865 ] Sun, 13 July 2014 22:48 UTC Go to previous messageGo to next message
Here is one method using Meshlab, for a Voronoi sphere
http://bit.ly/W1rLui
http://bit.ly/W1sdZD
Or in Blender, using the 'Wireframe' tool.
http://bit.ly/1rjr8ak
Re: Mesh / Honeycomb Effect [message #93906 is a reply to message #93869 ] Mon, 14 July 2014 12:55 UTC Go to previous message
I like the method using blender! I've never really gotten into blender, it doesn't run well on mac and i find it utterly frustrating that it can't follow the same guidelines that every other mac app uses. That said it does do a good job of creating the wireframe!
Previous Topic:mesh/organic cutout patterns on surfaces
Next Topic:2D to 3D design smaller than 30mm in width
