Well, you could sell them to your buddies, but you can also create a shop here on Shapeways real easily and Shapeways will sale them for you. All you do is sit back and do nothing while your share of the profits are sent to you on the 15th of every month.
If you take a look at an ordinary Zippo, the outer casing is a perfect fit to the inner fuel container. The clearance would be measured in the ten-thousandths of an inch. These outer casing are made via a deep drawing die that makes each one almost exactly like the last. Whereas, with 3D printing repeatability, getting the same dimensions every time, is not so accurate. More like wavering between 5 to 15 thousandths for every part or even worse, that is, for the 3D printing methods Shapeways uses for metals.
So you would need to compensate for that variable gap between parts with a gasket. In this situation as related to the design in question engineers would most likely use an o-ring gasket for this. It's simply a ring of elastomer that can be purchased in different sizes, materials and crossectional shapes. One of the numerous places to get them is
McMaster-carr.
Here's a diagram showing an example of how they can be used.
