Can I Check Wall Thickness offline using shapeways' tools
Can I Check Wall Thickness offline using shapeways' tools [message #92292] Thu, 19 June 2014 14:39 UTC Go to next message
avatar macouno  is currently offline macouno
Ok... so I have a bunch of models I'm creating for a customer, and of course I check the wall thickness in my own software (blender). But shapeways checks are often just a little different... and... the website is not always fast .
I was wondering if the shapeways toolset for checking wall thickness can be made available offline... then I can check my models without uploading. That could save a lot of time.
For instance right now I've been waiting 20minutes for the wall thickness check for ceramics in shapeways system... time best spent doing something else... but I need to get my models out asap.
Re: Can I Check Wall Thickness offline using shapeways' tools [message #92316 is a reply to message #92292 ] Thu, 19 June 2014 19:25 UTC Go to previous messageGo to next message
Actually...
I have three models that say "loading" for ceramics wall thickness check for 4hrs now... maybe I did something wrong? That's one reason it'd be nice to do this offline... then it's just me ;)
Re: Can I Check Wall Thickness offline using shapeways' tools [message #92319 is a reply to message #92316 ] Thu, 19 June 2014 19:47 UTC Go to previous messageGo to next message
You can check the wall thickness manually in Netfabb http://www.netfabb.com/basic.php
Re: Can I Check Wall Thickness offline using shapeways' tools [message #92320 is a reply to message #92319 ] Thu, 19 June 2014 19:58 UTC Go to previous messageGo to next message
Thanks... I know... And I'm sure it's possible but I'm also sure you can create a model that passes the chech in netfabb and fails for shapeways. That's why an offline shapeways chech would be nice.
Re: Can I Check Wall Thickness offline using shapeways' tools [message #92359 is a reply to message #92320 ] Fri, 20 June 2014 01:43 UTC Go to previous messageGo to next message
Knowledge Expert
Maybe the checking software it is made to run on a server not a local PC ?! And have some NDA on it ?...
numarul7 jewelry and design
Re: Can I Check Wall Thickness offline using shapeways' tools [message #92370 is a reply to message #92359 ] Fri, 20 June 2014 07:38 UTC Go to previous messageGo to next message
Small update... I'm still waiting (over 12hrs now) for the shapeways wall thickness check to show me whether or not the models pass ceramics checks...
Re: Can I Check Wall Thickness offline using shapeways' tools [message #92375 is a reply to message #92370 ] Fri, 20 June 2014 09:04 UTC Go to previous messageGo to next message
That sounds strange.
Could you share the model ID (the number you see in the URL of your web browser).
This way I can have it re-processed, cause it sounds like it stopped for some reason.
Customer Service Coordinator
Shapeways
Re: Can I Check Wall Thickness offline using shapeways' tools [message #92381 is a reply to message #92375 ] Fri, 20 June 2014 10:07 UTC Go to previous message
I sent you a PM,
I'm really curious to hear whether you can find out what the issue is... I've had this happen a lot with my models (getting stuck on ceramics).
Previous Topic:Optimize Airflow 3D model design , how to?
Next Topic:Hollow Tube on in STL Viewer. Two ends became enclosed after uploading
