Home » Support » 3D Design » more manifold problems spread across many models
more manifold problems spread across many models [message #9499] Tue, 02 February 2010 19:10 UTC Go to next message
avatar dymihail  is currently offline dymihail
deleted
[Updated on: Thu, 25 March 2010 20:30 UTC]
Re: more manifold problems spread across many models [message #9500 is a reply to message #9499 ] Tue, 02 February 2010 19:17 UTC Go to previous messageGo to next message
I can help, what formats can you export that aren't stl?
Re: more manifold problems spread across many models [message #9501 is a reply to message #9499 ] Tue, 02 February 2010 19:32 UTC Go to previous messageGo to next message
Thanks for the offer. Whatever Rhino exports; so 3ds, dxf, iges (I think), obj and a few others.
Re: more manifold problems spread across many models [message #9504 is a reply to message #9499 ] Tue, 02 February 2010 19:53 UTC Go to previous messageGo to next message
If it can export Iges that would be the best for me.
You can email them to me at youknowwho4eva@gmail.com
Re: more manifold problems spread across many models [message #9507 is a reply to message #9504 ] Tue, 02 February 2010 20:06 UTC Go to previous messageGo to next message
Thanks, I'll get a couple out tonight after I get home from work.
Re: more manifold problems spread across many models [message #9521 is a reply to message #9499 ] Wed, 03 February 2010 13:23 UTC Go to previous messageGo to next message
Hey dymihail!
In attach you find a fixed version of your file.
We are working on adding autofixing of files to our upload functionality. I used the same software to fix this file.
Cheers!
Robert
[removed model upon user request]
[Updated on: Thu, 25 March 2010 21:10 UTC]
Robert Schouwenburg
Re: more manifold problems spread across many models [message #9524 is a reply to message #9499 ] Wed, 03 February 2010 14:02 UTC Go to previous messageGo to next message
My problem with STL's is not only about that my main software doesn't like them much. But when you open an STL to do work, it's broken into polygons. All round surfaces are squared up. Then you fix it and export again, it breaks it differently. I've emailed you back about the file types I can work with. If you send me a solids file, I can heal it up and export as a high res STL. I always try to make my uploads at the polygon limit.
Re: more manifold problems spread across many models [message #9545 is a reply to message #9521 ] Thu, 04 February 2010 00:43 UTC Go to previous messageGo to next message
avatar akeno  is currently offline akeno
robert, autofixing would be amazing feature! there would be a ton more of customers who would be willing to upload without having the headache of fixing the manifolds and the such! omg!
Re: more manifold problems spread across many models [message #9557 is a reply to message #9521 ] Thu, 04 February 2010 06:27 UTC Go to previous messageGo to next message
robert wrote on Wed, 03 February 2010 13:23
Hey dymihail!
Cheers!
Robert
Doesn't seem like its caught the overlapping triangles, there's still about 13,000 in there. SDabbs and I ran up against this problem pretty badly with some of his models.
You should look into eliminating that check. Overlaps have never given my machines any trouble at all. But I understand that you're quotation system is probably messed up by them, so it might not be so easy.
Re: more manifold problems spread across many models [message #9560 is a reply to message #9557 ] Thu, 04 February 2010 07:51 UTC Go to previous messageGo to next message
Well it isn't perfect yet. Smile
Though this model uploads fine and is accepted by our validation software which is the most important thing.
You are right that overlapping triangles are fine for most printers.
Robert Schouwenburg
Re: more manifold problems spread across many models [message #9587 is a reply to message #9557 ] Thu, 04 February 2010 18:09 UTC Go to previous messageGo to next message
@crsdfr -- some of my models? IIRC, this is the only one that I've posted and available for download... not that I'm denying anything. My models are ugly. Been busy as all get out at work the last few days and haven't had the energy to do much modeling when I get home.
@robert -- auto-fixing software would be great. But as you said, it's not perfect. It cut a big hole in the top of the bridge. Well, "big" is relative on a ~45mm long model... But it was simple enough to work around and I certainly appreciate your work. Anytime you need more Guinea pig models, let me know. I have some right fugly ones.
I'll pop a few more up tonight in case anyone else is interested in seeing what I've been working on and is willing to take a look. Anything is appreciated, but certainly not expected.
Re: more manifold problems spread across many models [message #9605 is a reply to message #9587 ] Fri, 05 February 2010 01:23 UTC Go to previous messageGo to next message
dymihail wrote on Thu, 04 February 2010 18:09
Sorry, should of been clearer, SDabbs is another member here. I was trying to help him eliminate overlaps in some of his ZBrush models.
Your model looks good Smile Overlaps are just an artifact that you get sometimes converting into .stl.
Re: more manifold problems spread across many models [message #9698 is a reply to message #9499 ] Mon, 08 February 2010 07:09 UTC Go to previous messageGo to next message
deleted
[Updated on: Thu, 25 March 2010 20:31 UTC]
Re: more manifold problems spread across many models [message #9700 is a reply to message #9698 ] Mon, 08 February 2010 08:19 UTC Go to previous message
Same problem with this model, there are 117 shells.
Many of which sit almost perfectly next to eachother.
So, just like for the other thread/model : try boolean functions and reducing the shell count.
And make sure you don't place two objects with opposites faces, directly next to eachother.
Also try a different file format STL is terrible with crossing and overlapping shells.
But unfortunately, the way your models are currently build up, is prone to a lot of trouble.
Best is to work with one shell, and certainly not whole shells in shells, as this makes finding errors on the inside difficult Wink
[Updated on: Mon, 08 February 2010 14:20 UTC]
Previous Topic:Manifold Problem with this model
Next Topic:can't find inverted normals
