Thank you FreeRangeBrain,
that is extremely informative, such stuff needs to be on Shapeways web site as part of their information and guides to modelling and design.
I had a feeling that there might be a requirement for some post processing, I think my inclination will be to make the relevant holes to small and drill out as required using successive drill bits to get the required, then with ensuing prints adjust accordingly until I get the required fit, or at least ones that require minimal post processing.
I have seen a demo of the Ultimaker filament extruder print Lego blocks that worked, and it can print down to a resolution of 0.05mm (0.002") although I have heard they are getting them down to 0.02mm resolutions now !!!
But there are issues with overhangs and the like and making something that works in one print is very tricky etc. though there are some modification for dual head extruders and dissolveable support material etc.
WSF using SLS seems the way forward for me and the models I want to make given the intricate frame works required.
Good to find out about prints acquiring an additional thickness to the surface of the models.
Anyhow, your input is hugely appreciated, thank you very much
