I need to create an object with a flat face where a flat object will have to be manually inserted.
The first object will have a deboss (just discovered that this word exists, hope to be using it appropriately) of the same shape of the second object... that should be inserted in that space, creating a flat surface.
The second object will be glued to the first.
Hope you understood what I mean...
In attachment is a sample of the second object, it's size should be 3cmx3cm and thicnk 1 or 2 mm.
What kind of materials would you suggest for the first and second object? I want to order different combinations to test for the best result.
I would like to try stainless steel, matte black steel, black/white/royal blue strong and flexible plastic for the first object.
For the second, would you suggest detailed plastic or strong and flexible plastic?
Do you have any advice on how to model the two objects or on the materials choice?
I't a requirement that there must be a strong contrast between the colors of the two objects (black and white whould be ideal), so I'd like to try different options.
thanks,
Mattia
