Hi all, I would like to print a doll in 3D using the polished color version of the strong & flexible material, and was wondering what the appropriate thickness should be, so that the object is flexible, but also so that it does not appear transparent through light. Thanks for your help!
Hi. Take a look in material rules portfolio: https://www.shapeways.com/materials/strong-and-flexible-plas tic But if you want a relatively flexible doll, she have to be thin. But if you want to avoid a traslucent effect, then the thickness of the material reduces to 0 the flexibility. My advise? Make a test printed model. This part is less than a milimeter thick: Good luck with the doll. Regards. Luis
