Zmodeler and 3dsmax are doing a poor job with the boolean operations.
If you will save the file as an STL, and then grab a copy of Netfabb Basic from www.netfabb.com
You can open the file and see that around the edges there is a yellow line (hole in the model)
You can attempt to fix it in Netfabb, but often you're better off fixing it in the original program you drew it in.
But, Netfabb at least shows you where the problems are..
In case you don't know the steps to repair the model from here, check out this tutorial:
http://stonysmith.com/wired/Netfabb_Tutorial_2/default.asp
