Home » Community » Post Production Techniques » Painting "White Detail" models
Painting "White Detail" models [message #8963] Thu, 14 January 2010 16:45 UTC Go to next message
avatar finkgab  is currently offline finkgab
I was reading through the FAQ, and they said that the best material if you wish to paint over it is WS&F.
I need to get some models printed in White Detail, but I also have to paint them afterwards, so I was wondering if anyone has tried doing it before, and how did it go.
Pictures would be great too.
Thanks Smile
PS: I'm planning to use enamel paint.
Re: Painting "White Detail" models [message #10150 is a reply to message #8963 ] Tue, 23 February 2010 16:38 UTC Go to previous messageGo to next message
Same boat for me here.
I just ordered some WD parts, hopefully they turn out...
I was kind of thinking Krylon might work really well. Enamal paints would probably be fine too, as long as they get a good clear coat on top. Make sure you give each coat enough time to dry, otherwise the next layer will seal in moister and can actually "shift" if you rub it at all. (Yeah, My bro and I painted my model Heli, and it was perfect...but the first layers still had a small amount of moister, so the top layers shifted and now it looks like it crashed or something...haha)
Let us know how yours come out! Ill probably post my paint jobby as soon as I can.
Aut Viam Inveniam Aut Faciam
Re: Painting "White Detail" models [message #10795 is a reply to message #10150 ] Mon, 15 March 2010 22:31 UTC Go to previous messageGo to next message
I found some info on painting models printed my Objet printers...
http://www.objet.com/Misc/_Pages/Application_Notes_Left_Pane /Painting_of_PolyJet_Parts/
its slightly useful, it basically just says to use a lacqure primer coat.
Re: Painting "White Detail" models [message #32786 is a reply to message #8963 ] Tue, 16 August 2011 07:53 UTC Go to previous messageGo to next message
avatar Zephyr40k  is currently offline Zephyr40k
I've been working with some WD items I recently purchased from Shapeways. They look excellent, but upon priming them I am seeing an interesting phenomenon: the surfaces are becoming slightly "fuzzy." The paint dries just fine, but the slight bumpiness of the WD material becomes exaggerated when primered. I am using Armory-brand white primer, which is a pretty standard enamel primer I've always gotten good results with.
I am hoping sanding the items is not the only option. These items are small, complex, and highly detailed, so much so that sanding will (a) consume an extreme amount of time and effort and (b) probably result in a destruction of a large amount of surface detail.
So I am wondering if anyone else has had this occur. Is this due to humidity, perhaps? It was pretty humid today. Or is this just an inherent limitation of the WD material? Also, any tips for dealing with this? I am wondering if I could paint it as normal, then hit it with a glosscoat and then a dullcoat to smooth out the surface bumpiness. What do you think?
[Updated on: Tue, 16 August 2011 07:55 UTC]
Re: Painting "White Detail" models [message #32828 is a reply to message #32786 ] Wed, 17 August 2011 07:05 UTC Go to previous messageGo to next message
I dug out my Dremel Stylus and tried various sanding/polishing/buffing tips on the more inconspicuous parts of my items to see if I could reduce the bumpiness/fuzziness (the distinction comes from whether the moden had been primered already or not). I found that the only tip that really smoothed out the bumps in the WD material is the medium-grit sanding tip, and that removed too much material, threatening to destroy surface detail. So now I'm back to trying to smooth it out by layering paint. Anyone know of a spray paint that's viscous enough to smooth out the surface bumps but not so thick as to wipe out details in the approx. 2mm range?
Re: Painting "White Detail" models [message #32830 is a reply to message #32828 ] Wed, 17 August 2011 10:22 UTC Go to previous messageGo to next message
avatar Drawn-Steel Hero  is currently offline Drawn-Steel Hero
I'm not sure what's happened there; I've had no such troubles painting Detail, though granted I haven't used spray paints on it, so that may be the problem.
But hand painting them with acrylics (even fairly cheap craft acrylics), I still get good results, as long as I've made sure to clean the base model before painting, and use thinned coats of paint.The main reason I prefer WSF over Detail is that for my models, I necessarily get parts that rub together at joints, and in those situations, the paint can flake off Detail, whereas WSF can take it much better with only minor scuffing.
For static models, however, that's a non-issue.
Re: Painting "White Detail" models [message #32832 is a reply to message #32830 ] Wed, 17 August 2011 11:31 UTC Go to previous messageGo to next message
I think that, if you want to paint Detail it is a good idea to soak the parts in caustic soda solution to ensure that all the support material has been removed. This seems to be especially the case if you want to use oil based paints, eg enamels.
Bill Bedford
Re: Painting "White Detail" models [message #32855 is a reply to message #32832 ] Wed, 17 August 2011 16:24 UTC Go to previous messageGo to next message
It's not the presence of support material that is causing this. All the pieces, I soaked in hot detergent solution and scrubbed with a brush before painting. I then dipped them in extremely hot water to see if any more wax would come off, and none did. I have sone that I have not sprayed yet, and I checked them carefully just now and there's no wax on them. I'll try a brush-on primer, see how that goes.
No comments from anyone on the humidity? I seem to recall the last time I painted something and it got 'fuzzy' it was also foggy outside. That was a metal miniature.
Re: Painting "White Detail" models [message #32857 is a reply to message #8963 ] Wed, 17 August 2011 16:31 UTC Go to previous messageGo to next message
Well, as I said, I don't spray myself, but I do know from others that spray paints often develop odd textures when use in 'extreme' conditions (e.g, too hot, too cold, too humid), so it's entirely possible the weather just wasn't right for spraying that day. One of the many reasons I stick to brushwork is that I don't have to limit myself to certain times and places to do it.
Re: Painting "White Detail" models [message #32860 is a reply to message #8963 ] Wed, 17 August 2011 17:15 UTC Go to previous messageGo to next message
Here you can find WSF (left) and white detail (right) painted.
As mentioned above spraying is extremly vulnerable by the environmental situation (humidity, ... )
So I only brush my parts.
http://farm6.static.flickr.com/5178/5461650382_37fdc45497.jpg
Woody64
Re: Painting "White Detail" models [message #32861 is a reply to message #32860 ] Wed, 17 August 2011 17:44 UTC Go to previous messageGo to next message
That's a great paint job, woody! The details on the two figures are amazing. OK, that's great; if you can get that smooth a paint job with WD and WSF, that gives me hope. What kind of surface prep did you use on these items?
Re: Painting "White Detail" models [message #32863 is a reply to message #32861 ] Wed, 17 August 2011 18:06 UTC Go to previous messageGo to next message
WSF polished colored blue
FD colored grey
http://farm7.static.flickr.com/6147/5939580888_a6f70c6f0e.jpg http://farm7.static.flickr.com/6006/5939014561_eec729807d.jpg
So far I did nothing for preparation. It seems that some colours have better results then others.
I use Acryl water based colours (2 in 1 - including the primer)
See also here
http://www.flickr.com/photos/34336019@N07/5771156365/in/phot ostream
The grey did extremely well with 1 coat!
I also had some other colours which did not as well.
Take a look on my flickr gallery to see results. I've experimented a lot since for me colours are so missing in the shapeways offer.
Woody64
[Updated on: Wed, 17 August 2011 18:18 UTC]
Re: Painting "White Detail" models [message #32902 is a reply to message #8963 ] Thu, 18 August 2011 17:41 UTC Go to previous messageGo to next message
I called around to various art supply stores in the area and the only brush-on primer I could find was Liquitex Gesso. Anyone ever use that on a Shapeways item? How well did it work?
Re: Painting "White Detail" models [message #32905 is a reply to message #8963 ] Thu, 18 August 2011 18:03 UTC Go to previous messageGo to next message
You don't want to be using gesso as a primer for models - that's for priming canvases, and is designed partially as a gap-filler - totally not what you need.
You don't really need a specific primer paint for small models like this - just apply a couple of coats of white, grey or black paint (depending on the colours you plan to use), so you've got nice even coverage, and something to give the actual paint job something to adhere to.
If you do specifically want something primer-like, you could try Vallejo's Model Color Foundation White, or the Citadel Foundation paint range from Games Workshop.
Re: Painting "White Detail" models [message #32907 is a reply to message #8963 ] Thu, 18 August 2011 19:12 UTC Go to previous messageGo to next message
Yeah, none of the hobby stores or art stores in the area had any brush-on primers, vallejo, citadel, reaper, or any other brand. Weird.
I'll try some normal (non-primer) vallejo white on the piece in an inconspicuous place... what I really need is something to smooth out the minor rippling in the surfaces of the shapeways items without obliterating the details.
Re: Painting "White Detail" models [message #32909 is a reply to message #32907 ] Thu, 18 August 2011 20:23 UTC Go to previous messageGo to next message
That'll do you nicely. Just remember to thin the paint a little to help it flow better, and it should gradually fill up any imperfections.
Re: Painting "White Detail" models [message #32921 is a reply to message #32902 ] Thu, 18 August 2011 22:22 UTC Go to previous messageGo to next message
Vallejo has brush on primers... a bit bubble prone when used with a brush, tho. You can try with that gesso, not so uncommon, primer.
Another trick is using Milliput slurry, which is sandable, or matte varnish (toughter than plain paints), as they have a bit more filling capabilities. The Milliput trick is rather old, and depends in the property of that epoxy to "disolve" into water, forming a "paint". Try the fine grade for smoother results.
Re: Painting "White Detail" models [message #32924 is a reply to message #8963 ] Fri, 19 August 2011 01:25 UTC Go to previous messageGo to next message
That's funny, I was about to link to this thread:
http://www.warseer.com/forums/showthread.php?t=65373
Which says pretty much the same thing. I think I'll try the Gesso on a couple of throwaway (non-shapeways) figures first, see how it goes.
Re: Painting "White Detail" models [message #32925 is a reply to message #32924 ] Fri, 19 August 2011 01:30 UTC Go to previous messageGo to next message
Hmm... I shall consider myself schooled. I guess it's because the gesso I'm used to is really thick (like, almost solid); I hadn't considered that it comes in a more viscous form suitable for stuff like this.
Re: Painting "White Detail" models [message #32995 is a reply to message #8963 ] Sat, 20 August 2011 10:18 UTC Go to previous messageGo to next message
So I painted a couple of my shapeways figures with gesso, lo and behold they still got fuzzy. I painted a non-shapeways pewter figure, and the gesso went on great, dried perfectly smooth, no problems.
So it's not the humidity at all. The brush-on gesso looks the same as the spray-on Armory primer.
I've put a couple more layers of gesso on my shapeways models, let's see how they look after a few coats. Hopefully the texture will smooth out a bit.
Re: Painting "White Detail" models [message #33164 is a reply to message #8963 ] Tue, 23 August 2011 17:16 UTC Go to previous messageGo to next message
I've been painting a layer of Gesso on my WD figures each day for a few days now, and it definitely smooths out the rough surface texture significantly. I'm trying to find the "sweet spot" where the model is smooth enough I can wash and ink it without it coming out looking fuzzy, but not so much Gesso that it will obliterate surface detail. I do believe this is possible, but it's turning out to be significantly more effort than I anticipated. I don't blame Shapeways, I figure it's just a limitation of the technology as it currently stands. I think the next item I order from Shapeways I'll try that "WS&F Polished;" I get the impression that I won't have these issues with that production technique.
Re: Painting "White Detail" models [message #33176 is a reply to message #33164 ] Tue, 23 August 2011 19:45 UTC Go to previous messageGo to next message
Take a look above to my pWSF example. Indeed the surface becomes much smoother and there`s only 1 layer of paint.
Unfortunately the order timegets doubled.,
Woody64
Re: Painting "White Detail" models [message #33200 is a reply to message #33176 ] Wed, 24 August 2011 02:06 UTC Go to previous message
So now I'm looking at your figures again... is the entire LEGO-man a Shapeways creation, or just the helmet? They seem to be a bit different consistency from the rest of the unit.
Previous Topic:Can WD be heated and reshaped?
Next Topic:Dyeing Results
