Home » Community » Shapeways Shops » Co-Creator Volume
Co-Creator Volume [message #8749] Tue, 05 January 2010 19:46 UTC Go to next message
Why is the Co-Creator Volume needed? The way I do my co-creators is the model I upload is designed to be the max volume, Then I have to go check the volume to insert it. Any way this can be made to use the volume of the uploaded model if not filled in? And I haven't tried this yet, but is the system set up to stop an order and display an error of an upload exceeds this volume?
Re: Co-Creator Volume [message #8947 is a reply to message #8749 ] Wed, 13 January 2010 22:34 UTC Go to previous messageGo to next message
If your uploaded model already has the correct volume, there is an easy way to obtain its value without going back to your modelling software:
- if you are out of Europe, take its price (without markup) in Stainless Steel and divide it by 10.
- if you are in Europe, divide it by 10 and then by 1.19 (cause the price you see includes the VAT)
Hope this helps...
[Updated on: Wed, 13 January 2010 22:39 UTC]
Re: Co-Creator Volume [message #8961 is a reply to message #8749 ] Thu, 14 January 2010 13:37 UTC Go to previous messageGo to next message
Just as easy to do a mass properties and hit cm in my software, but I think something needs to be changed about the co-creators, pricing, and volume.
Re: Co-Creator Volume [message #9316 is a reply to message #8749 ] Wed, 27 January 2010 21:21 UTC Go to previous messageGo to next message
avatar pp  is currently offline pp
Working on it.
The solution you are talking about is good.
I am now looking to have this filed auto filled with the volume of the model you turned into a template. This filed will be editable if you want....
Hope to be able to offer this soon.
We post any new features or functionality releases in the organizational announcement. Keep you eye on it.
Any other ideas on the pricing of Creators?
Peter Paul
Re: Co-Creator Volume [message #9393 is a reply to message #8749 ] Fri, 29 January 2010 19:00 UTC Go to previous messageGo to next message
What about an "open volume"? So the item wouldn't have a set volume or price. It's listed price would/could be something like the max. Less volume less cost. More volume (with customer approval) more cost.
Re: Co-Creator Volume [message #9414 is a reply to message #9393 ] Sat, 30 January 2010 12:59 UTC Go to previous messageGo to next message
Hi guys,
the volume question is a valid one. Perhaps we can discuss this, because it is not easy to solve.
We need to solve the following:
You price a co-creator item at a certain price.
Why? Because when someone orders it, he pays BEFORE you start modeling it.
After ordering the shop owner remodels according to specs and it is then mandatory not to exceed the max volume otherwise the customer has not paid enough. That is why the max volume is needed.
Now we could change the flow, but that would mean that the customer only pays after you remodel, however due to time lag, your conversion to order will be <100% and probably significantly so.
Feedback appreciated.
Pete
[Updated on: Sat, 30 January 2010 12:59 UTC]
Re: Co-Creator Volume [message #9417 is a reply to message #9414 ] Sat, 30 January 2010 13:28 UTC Go to previous messageGo to next message
I'm happy with the current system !! Smile
Any variability would undermine the ease of buying : customer sees product, fills in details, orders and pays.
Which is the strong point of the co-creators I think.
For other more complicated or custom jobs we are only a personal message away to the customer. Which seems less complicated than a customer who can select a model but then has to wait for a final price..
And my experience so far is, that if a customer wants something different, they have no trouble in messaging/contacting me.
Re: Co-Creator Volume [message #9458 is a reply to message #8749 ] Mon, 01 February 2010 15:11 UTC Go to previous messageGo to next message
It is a very tricky widget. I do forsee, if it hasn't happened yet, someone ordering a co-creator from a no longer active member. I know personally I'd take a pay cut if the volume were more then listed, as long as when it's less I get a pay increase instead of shapeways getting it when the volume is less.
Re: Co-Creator Volume [message #10073 is a reply to message #9414 ] Sat, 20 February 2010 16:24 UTC Go to previous messageGo to next message
I'm pretty happy with the current pricing model too - it is a bit weird, and could maybe be described differently, but I don't think it's a bad solution to a tricky problem. The selling price has to be fixed for the reasons Pete says.
But I would like to be able to set a retail price, rather than arrive at a retail price by adding my markup. And my retail price would be equal to the printing cost of the largest version of my model plus whatever minimum markup I decided to award myself. If the model was smaller, then my profit margin would be slightly higher. If I didn't properly specify the boundaries of the sizing parameter, and someone ordered a gigantic version, then I might end up making no profit at all, and that would be my own fault.
I think at the moment there is almost a disincentive to use co-creators because the actual cost of the model will always work out to be a little cheaper than what is charged, and so sellers think they should receive the difference as extra profit, and buyers would prefer to just pay slightly less in the first place. It creates an reason to try and work outside the shapeways selling model, if you see what I mean, and arrange the sale manually with a specially listed model instead.
Personally I am not bothered about the few cents difference that shapeways gets to keep if a customer orders a small model with the current co-creator method - I see it as a commission fee paid to shapeways for arranging the sale. But I would prefer to be able to specify a particular retail price without so much guesswork.
Re: Co-Creator Volume [message #10123 is a reply to message #9414 ] Mon, 22 February 2010 23:54 UTC Go to previous messageGo to next message
avatar shaputer  is currently offline shaputer
I've been trying to upload my bike opener to a customer since last Friday. I keep getting that volume error message. I don't want the person to think I didn't update the model. Because I did. I keep trying to upload and I get errors, but the model is printable if I upload as a separate model. I don't care if I get paid for this one. I just want the customer to get the model.
Please Help
Thanks!!!
Re: Co-Creator Volume [message #10125 is a reply to message #10123 ] Tue, 23 February 2010 07:24 UTC Go to previous messageGo to next message
You mean that the problem is that the model you are uploading has a volume that is a bit larger that what you indicated into the co-creator form, right?
Unfortunately, the only way to be able to upload the customized model is to reduce its volume so that it is equal or inferior to what you previously indicated.
I had this issue and the difference was ridiculously low, so I just applied a scale of 99.95% to the customised model and was then able to upload it.
If this does not work for you, you could perhaps first update your co-creator model with the correct maximum volume value and then contact you customer or Shapeways in order to cancel this order, and ask the customer to order again...
Re: Co-Creator Volume [message #10127 is a reply to message #10123 ] Tue, 23 February 2010 10:30 UTC Go to previous messageGo to next message
Hi Shaputer,
We managed to get the file fixed. It was done automatically so I can't exactly let you know what was wrong. It wasn't the volume Wink
The fixed file should be in your mail box now.
We also have added the file to the order so this is proceeding to production. We will do our best to make up for the delay.
rgds Peter Paul
icon14.gif  Re: Co-Creator Volume [message #10129 is a reply to message #10125 ] Tue, 23 February 2010 11:56 UTC Go to previous messageGo to next message
Thanks I actually did what you said. The new model is actually slightly smaller. I had to adjust the size a little for functionality purposes.
I get this error: "It did not pass the check Volume validation"
I updated the model template already. I'll try to have the customer cancel and reorder so It will work.
Thanks for your help,
Shana Very Happy
Re: Co-Creator Volume [message #10130 is a reply to message #10127 ] Tue, 23 February 2010 11:57 UTC Go to previous messageGo to next message
WOW !!! Thanks !! Just noticed your post. Will look for that !!!
Shapeways IS THE BEST !!
Re: Co-Creator Volume [message #10132 is a reply to message #10127 ] Tue, 23 February 2010 12:01 UTC Go to previous messageGo to next message
pp,
I didn't get that fixed file in my inbox. Did I miss something ?
Re: Co-Creator Volume [message #10134 is a reply to message #10132 ] Tue, 23 February 2010 12:19 UTC Go to previous messageGo to next message
Just re-send it to you via PM
Re: Co-Creator Volume [message #10136 is a reply to message #10134 ] Tue, 23 February 2010 12:47 UTC Go to previous message
GOT IT
Thanks again
Previous Topic:shop categories don't work
Next Topic:Image mapping
