Wall thickness issues
Wall thickness issues [message #84550] Sat, 08 February 2014 03:25 UTC Go to next message
avatar IceDragon2013  is currently offline IceDragon2013
I have my model working and ready for order, but it would seem i have a problem with the wall thickness.
Im not sure how to work around on 'repairing' it. This is surely a tricky situation for me as i have tried my best.
As you can see on the file, it highlights the thin area. To be honest, it seems workable to me.
  • Attachment: Untitled.jpg
    (Size: 107.04KB, Downloaded 70 time(s))
Re: Wall thickness issues [message #84561 is a reply to message #84550 ] Sat, 08 February 2014 11:04 UTC Go to previous messageGo to next message
How wide are the tapered areas ? If they do not extend over more than twice the minimum thickness, it should work. The automatic wall thickness test in not that sophisticated - its message is more like "check if you really intented these regions to be so thin"
Re: Wall thickness issues [message #84576 is a reply to message #84550 ] Sat, 08 February 2014 16:21 UTC Go to previous messageGo to next message
As a side issue: how long is this item?
Since it's a weapon, it must be less than 10cm long.
See the policy here: https://www.shapeways.com/legal/content_policy
Re: Wall thickness issues [message #84577 is a reply to message #84576 ] Sat, 08 February 2014 16:44 UTC Go to previous messageGo to next message
I don't think whether it's a weapon or not will really be an issue - trying to print it in ceramic (as the screen shot indicates) will probably throw up enough problems on its own. Square, thin edges, sharp point, no discernible base, for example.
Re: Wall thickness issues [message #84583 is a reply to message #84576 ] Sat, 08 February 2014 18:42 UTC Go to previous messageGo to next message
its about 4.6'
i dont intend on making weapons. NO!
this is just a test run to see if ceramic jewelry/keychain is feasible.
If ceramic doesn't work out, i'll have to try another material.
4.6 seems like the "right" size actually. I tried to make it 2.5 but it was too small for printing. anything bigger than 5.8 was too big...
Re: Wall thickness issues [message #84584 is a reply to message #84561 ] Sat, 08 February 2014 18:48 UTC Go to previous message
22.548mm widest
6.404mm thickness of the blade
Previous Topic:Fixing the model - help needed - resolved - Thanks to Pavan Ganti!
Next Topic:Wire ring not polished, help ?
