Wall thickness
Wall thickness [message #84290] Mon, 03 February 2014 19:12 UTC Go to next message
avatar drhughharvey  is currently offline drhughharvey
Hi guys,
I have had some success getting some anatomical models printed, but one of my vertebral body models keeps getting rejected as having walls that are too thin, despite netfabb giving the all clear.
Now, I'm not really any good with Blender, so can anyone help me or tutor me in a good method to FIND the thin walls and then make JUST those walls thicker?
I've tried the solidify modifier, but that does all the walls.
Also, there are bits 'floating' inside the body of the model - any ideas how to remove them? Again, a tutorial or explanation would be great!
The .stl can be found attached
Many thanks in advance!
Re: Wall thickness [message #84302 is a reply to message #84290 ] Mon, 03 February 2014 21:01 UTC Go to previous messageGo to next message
For finding them, have you tried the "3d printing toolbox" addon (comes with blender, but has to be enabled in Preferences) ?
For correcting them, I am not sure - frogs and blenders don't mix well - but maybe once the toolbox check highlights them, the solidifier
acts only on these ?
Re: Wall thickness [message #84309 is a reply to message #84302 ] Mon, 03 February 2014 22:41 UTC Go to previous messageGo to next message
Open the Model in Netfabb Basic.
Select Repair.
Right click the model, and pick "Select this Shell"
Right click again, and pick "Extract these triangles as separate part".
Then, right click a 3rd time and pick "Export".
That will remove the "floating bits" - it's entirely possible that that floating piece itself was the source of the "too thin" rejection.
If you want to see the floating part:
Select Repair.
Right click again and pick "Remove selected Triangles"
This will show you the floating bits... To back out and avoid making any changes, just close the program.
  • Attachment: L2smoothA.stl
    (Size: 33.12MB, Downloaded 52 time(s))
Re: Wall thickness [message #84311 is a reply to message #84309 ] Mon, 03 February 2014 22:48 UTC Go to previous message
Worked a treat in removing the debris!
I'll try getting this printed again - hopefully the thin-wall problem has been solved!
Previous Topic:separate parts
Next Topic:Engraving with a rounded grove in Blender
