Home » Support » 3D Design » Wire thickness/ Making the object from "hollow" to "solid"?
Wire thickness/ Making the object from "hollow" to "solid"? [message #84190] Sat, 01 February 2014 16:09 UTC Go to next message
avatar Lolzydude1  is currently offline Lolzydude1
Hey there guys/girls I'm pretty new to Shapeways and 3D modelling in general, everything was running smoothly till the point where I actually wanted to print my 3D model, the issue I'm having is that the wire thickness of the model is too thin, I'm currently using 3DS Max but open to trying other software to fix the issue, I've tried using the Shell modifier in Max and the solidify modifier in Blender, my question is: is it possible to "fill" the 3d model to make the hollow areas within the model solid, so there isn't any issues with the model faces being too thin, or the wireframe? Any help would be greatly appreciated, cheers.
  • Attachment: a.jpg
    (Size: 38.95KB, Downloaded 32 time(s))
  • Attachment: b.jpg
    (Size: 49.99KB, Downloaded 23 time(s))
  • Attachment: c.jpg
    (Size: 99.19KB, Downloaded 26 time(s))
  • Attachment: d.jpg
    (Size: 21.22KB, Downloaded 25 time(s))
  • Attachment: e.jpg
    (Size: 82.20KB, Downloaded 28 time(s))
Re: Wire thickness/ Making the object from "hollow" to "solid"? [message #84192 is a reply to message #84190 ] Sat, 01 February 2014 16:19 UTC Go to previous messageGo to next message
If the problem is limited to the hollow gun barrels, closing the ends should be sufficient to make shapeways' software treat them as solid.
Re: Wire thickness/ Making the object from "hollow" to "solid"? [message #84193 is a reply to message #84192 ] Sat, 01 February 2014 16:33 UTC Go to previous messageGo to next message
Hi I've fixed the shotgun the image is slightly outdated, before uploading it I had deleted some of it's faces by accident, but The ealls are apparently still too thin on the whole model (except for the base). or at least I'm still getting the "View Thin walls" error message when uploading, cheers.
Re: Wire thickness/ Making the object from "hollow" to "solid"? [message #84195 is a reply to message #84193 ] Sat, 01 February 2014 17:29 UTC Go to previous messageGo to next message
The wall thickness check can generate false positives where there are small surface details, best get netfabb studio basic from netfabb.com to measure the model yourself. And again if you close all openings the model should be treated as solid by shapeways, no matter how many internal walls it has. (Could be a bit expensive then, depending on the overall size of that figurine)
Re: Wire thickness/ Making the object from "hollow" to "solid"? [message #84196 is a reply to message #84195 ] Sat, 01 February 2014 17:52 UTC Go to previous message
I think the problem may be that the barrel and torch are just too thin for FCS ...
Previous Topic:*.WRL to X3d or format Blender can read!
Next Topic:separate parts
