Help to convert my file
Help to convert my file [message #79701] Sun, 24 November 2013 10:08 UTC Go to next message
avatar megsempinado  is currently offline megsempinado
Hello fellows,
I need to convert my .stl file into a solidworks file and into a parasolid .x_t , but i don't have this software.Attached is the .stl file.I hope you could help me.
Thanks in advance,
Megs
  • Attachment: rudolph.stl
    (Size: 9.81MB, Downloaded 49 time(s))
3d artist philippines
Re: Help to convert my file [message #79717 is a reply to message #79701 ] Sun, 24 November 2013 19:15 UTC Go to previous messageGo to next message
avatar Ronsaki  is currently offline Ronsaki
There is no automatic way to convert .stl files into solid models.
I've been working at a reverse engineering company where they converted scan data (.stl files) into solid formats.
You need a special kind of software for that, (I think we used GeoMagic or something like that), and it's still a time consuming job.
For a simple model, easiest way is to redraw it in Solidworks, but a model like this, that's not an option. Your only option is to find someone who specializes in turning .stl files in solid models, but for a model like this, that will be quite expensive.
[Updated on: Sun, 24 November 2013 19:17 UTC]
Re: Help to convert my file [message #79731 is a reply to message #79717 ] Mon, 25 November 2013 00:08 UTC Go to previous messageGo to next message
Thank you Sir Ron.
Re: Help to convert my file [message #79732 is a reply to message #79701 ] Mon, 25 November 2013 00:18 UTC Go to previous messageGo to next message
I have a nurbs surfaced model but some areas need filled in with a surface.
Then you have some real conversion options.
I will pm you with details if you want this
index.php?t=getfile&id=45854&private=0
  • Attachment: Rudolph.jpg
    (Size: 271.01KB, Downloaded 111 time(s))
Re: Help to convert my file [message #79772 is a reply to message #79732 ] Mon, 25 November 2013 14:29 UTC Go to previous messageGo to next message
Do you just want the model made solid so you can make it hollow to save on price?
I can make it hollow with a 1.25mm wall thickness
This has a 30.24cm3 volume, compared with your original model at 154.74cm3.
You can have the model if you want it.
index.php?t=getfile&id=45872&private=0
  • Attachment: rudolph.png
    (Size: 302.68KB, Downloaded 92 time(s))
Re: Help to convert my file [message #79782 is a reply to message #79772 ] Mon, 25 November 2013 15:44 UTC Go to previous message
Thank you Sir Jacant and Sir CadNinja. I really appreciate your help.Thanks a lot.
More Power,
Megs
Previous Topic:Church Organ
Next Topic:'2011 Triumph Street Triple R' motocycle model wanted
