Image popper
Discussion in 'General Discussion' started by 410200_deleted, Oct 29, 2013.
  1. Shapeways used to let you put a base rectancle of material behind a popped 2D image. I need to makr stamps out of 2D images. Any ideas on how to do that?
  2. Youknowwho4eva
    Youknowwho4eva Well-Known Member
    The only current way to do this is to add a grey background to your image. I've requested that this option be brought back.
  3. Youknowwho4eva
    Here's an example with a grey background [​IMG]
    and the result[​IMG]
  4. MitchellJetten
    MitchellJetten Shapeways Employee CS Team
    But will it be thick enough with grey?
  5. bartv
    bartv Member
    The image popper linearly maps the brightness of your image to thickness. So, if you set a 3mm thickness in total, 100% black = 3mm thick. Use a 50% black background for a 1.5mm thick back plate etc.
    To be 100% sure, you can download the model and measure it in NetFabb :)
  6. MitchellJetten
    thank you for explaining Bart :)
  7. bartv
    bartv Member
    It's not often that I know something that you don't, so I couldn't let that opportunity pass ;)
