Home »  » 3D Applications » Autodesk ReCap
Autodesk ReCap [message #76688] Mon, 14 October 2013 12:39 UTC Go to next message
avatar anykey  is currently offline anykey
I am using Autodesk recap to generate 3d models from photos. (like 123d catch, but then higher resolution). The quality of models i am getting is great, I just do not know how to export this to files that shapeways understands, at least not to retain the colors.
Does anyone have experience with this?
Regards,
Richard
Re: Autodesk ReCap [message #76689 is a reply to message #76688 ] Mon, 14 October 2013 12:49 UTC Go to previous messageGo to next message
No experience with recap, but have you tried getting the mesh in OBJ format and uploading that to shapeways ?
Re: Autodesk ReCap [message #76690 is a reply to message #76689 ] Mon, 14 October 2013 12:50 UTC Go to previous messageGo to next message
yes, that works fine, but no color/texture
Re: Autodesk ReCap [message #76693 is a reply to message #76690 ] Mon, 14 October 2013 13:27 UTC Go to previous message
OK, so at least the mesh part works, but you will need a VRML/X3D or Collada/DAE file to get the textured mesh in a format that shapeways can handle. Can you try opening the OBJ in meshlab or blender ? If you see the texture there, try exporting to DAE or
X3D. (At least the latter will have the textures as a separate image file that needs to be zipped together with the .x3d file for upload)
Previous Topic:What is the best way to make gears in Blender 3D?
Next Topic:Uploading Issues
