A good bit of the answer depends upon how large you want to make the item.
If you keep the planet and the ring, then the spaceship will disappear because it's so small.
If you remove the planet, ring, and moon, keeping only the spaceship, the support posts have too small of a diameter, and the logo is going to disappear.
Then, the tiny antenna on the top, and the engine nozzles are not "closed", the big end of each cone is open, and you will need to fix that.
The base platform above the engine nozzles needs to be thicker. and the top antenna is too small.
Next to last, the engine nozzles will break off during cleaning - this is a common issue for codes attached to larger surfaces - it shears off at the connection. Making the nozzles a bit larger and using fillets may help.
Last, some of the things above can be fixed simply by increasing the size of the item (say 2x larger), but once you do that, you may wish to make the whole model hollow so as to bring down the cost.
