I ordered 2 prints of the same model that has a long thin part (the 194mm one) that turned out 2mm longer than the actual model in one of the prints while the other was fine. I am attaching a picture of the long part, and if someone needs it, I can also upload a photo of the difference.
Could someone help me with the following questions:
[list type=square]
[*] Is the inaccurate length (+2mm) of the long part due to
warpage or a one-off printer error?
[*] Is the model too thin? Shapeways recommends a 10 to 1 ratio for height vs thickness to avoid warpage, so, a 193mm long wall, should be 19mm thick?
[*] Would a hollowed rectangle (eg: 3x3mm hollowed for 1mm thick walls) instead of a T shaped rib solve such issues? Or it must be thicker? I want to keep the price down, so if another shape works that has similar thickness would be fab.
[/list]
