Home » Community » Post Production Techniques » resizing / stretching stainless steel
resizing / stretching stainless steel [message #7701] Mon, 09 November 2009 22:51 UTC Go to next message
Hi, does anyone know how the metal material reacts to being stretched or compressed, as in a ring-resizing machine? I have made a ring that has some prongs on it for holding a stone, and these are just about springy enough to grip the stone, but I found they snapped much more easily than a wrought metal would.
I'm curious as to how larger masses behave under stress. I don't really have anything precise enough to try that wouldn't just indicate "yeah, if I hit it, it breaks".
cheers!
Re: resizing / stretching stainless steel [message #8023 is a reply to message #7701 ] Wed, 02 December 2009 04:56 UTC Go to previous messageGo to next message
Thats pretty much the nature of the beast. It will give a tiny amount before the dreaded "snap". This material is very similar to what is called malleable cast iron. In can move a little bit, but it can not be hammered or bent very much before it breaks. The only safe way to "size" a ring would be with stock removal. If you are trying to set gemstones in prongs you might have to rethink your design. Better to fabricate the setting out of wrought metal and then solder them to the DMP ring body.
-G
Leonardo da Vinci
Re: resizing / stretching stainless steel [message #8029 is a reply to message #8023 ] Wed, 02 December 2009 14:18 UTC Go to previous messageGo to next message
Cheers Glen, the granulated look of the surfaces made me think that was probably the case.
I have one stone set from just snapping it in, but it's with very long prongs, so I guess there's enough flex to let me get away with it, and I was lucky too, I think.
sn
Re: resizing / stretching stainless steel [message #8270 is a reply to message #8029 ] Sat, 12 December 2009 16:30 UTC Go to previous messageGo to next message
Hi euphy,
can you share a pic? Would love to see the result.
regards,
Peter
Re: resizing / stretching stainless steel [message #8278 is a reply to message #8270 ] Sat, 12 December 2009 17:48 UTC Go to previous messageGo to next message
This version just held the stone in with tension alone as the stone pushed the prongs apart (the roughness of the metal surface meant it could "grip" the stone a bit too):
http://farm3.static.flickr.com/2475/3987806082_81037f1042_m.jpg
But I put some claws on the ends of the prongs for this version to hold it in more securely:
http://farm3.static.flickr.com/2433/4043177220_5e7f79b44a_m.jpg
Re: resizing / stretching stainless steel [message #8279 is a reply to message #8278 ] Sat, 12 December 2009 17:57 UTC Go to previous messageGo to next message
thanks, looks really cool! Expensive gems?
Looks like a nice thing to sell in our shops.
regards,
Peter
Re: resizing / stretching stainless steel [message #8281 is a reply to message #8279 ] Sat, 12 December 2009 18:06 UTC Go to previous message
Thanks! It's a pretty half carat diamond I got offof ebay years ago, but it wasn't expensive because it's very flawed - full of dirt!. Lovely colour though.
Previous Topic:painting white detail + black detail model
Next Topic:Example of primed WSF or white detail?
