Home » Support » 3D Applications » SketchUp uploading and missing texture... what?
SketchUp uploading and missing texture... what? [message #73424] Thu, 22 August 2013 02:35 UTC Go to next message
avatar TrainThingz  is currently offline TrainThingz
OK, I've figured out Sketchup (I thought!), designed my first simple project, and uploaded it to Shapeways... and now it's making me crazy.
I'm getting an error "Texture file not found: plateK.jpg", and it's telling me I need to upload it... but HOW? The uploader won't let me select both files. Even more aggravating... there's not any texture on the model! Now, I USED a texture as reference when I made it, but I've been over every face of the thing now, and it's not there any more. I selected the entire thing and painted it, clearing the faces, too.
So... I'm getting an error for not uploading something that isn't there, and even though I would be willing to upload the texture, there's no apparent way to DO it, and it doesn't seem to be mentioned in any of the Shapeways documentation!
It's got me pulling my hair out... and I can't afford to lose any more of it! That's the only error message I'm getting (so far) so I'm hoping that I have an otherwise good model...
Re: SketchUp uploading and missing texture... what? [message #73435 is a reply to message #73424 ] Thu, 22 August 2013 05:44 UTC Go to previous messageGo to next message
Look at this and then search the forums for the many posts on the subject https://www.shapeways.com/tutorials/exporting_to_vrml_and_x3 d_for_color_printing
Re: SketchUp uploading and missing texture... what? [message #73436 is a reply to message #73435 ] Thu, 22 August 2013 05:53 UTC Go to previous messageGo to next message
OK, so it wants the files zipped... Does that still hold with a .dae file? It's neither VRML nor X3D.
Now if you could only explain why it wants a texture file at all, since it's not used on the model!
[Updated on: Thu, 22 August 2013 05:54 UTC]
Re: SketchUp uploading and missing texture... what? [message #73437 is a reply to message #73436 ] Thu, 22 August 2013 07:01 UTC Go to previous messageGo to next message
As far as I know, DAE uses embedded textures, so you would only need to upload the single DAE file (which you could
still zip for faster upload).
And only you can know where the requirement for the "plateK.jpg" texture file comes from - shapeways cannot make up this name,
so it must be assigned to your model somewhere (and hence referenced in an imageTexture statement in your wrl/x3d file (which is readable text).
Perhaps a global setting somewhere in your software, or a very tiny, easy to overlook face still has it assigned ?
Re: SketchUp uploading and missing texture... what? [message #73439 is a reply to message #73436 ] Thu, 22 August 2013 07:04 UTC Go to previous messageGo to next message
Well, I did not read that yo do not want the texture at all. Do not provide a .jpg, do not zip anything..
Try exporting in a different format. You clearly have colour/texture associated with your model even if it is 'no colour'. If you use a format that does not support colour this should not be a problem, .stl for example. I don't know what formats you have available, try experimenting.
Re: SketchUp uploading and missing texture... what? [message #74006 is a reply to message #73439 ] Sun, 01 September 2013 03:16 UTC Go to previous message
avatar dcyale  is currently offline dcyale
There is a plug in for sketchup that will remove all textures from you model at: http://sketchucation.com/forums/viewtopic.php?p=140672#p1406 72
Go to http://sketchucation.com/ for a wealth of sketchup tutorials, plugins and some very knowledgeable people.
Previous Topic:Been a shapways user for almost three years suddenly everything is wrong
Next Topic:"Invert" existing model (i.e. similar process to making a mold )
