Shapeways USA just announced 14k Gold, read more on the blog
Home » Community » It arrived! » My first Gold Plated Brass Ring is a Success
My first Gold Plated Brass Ring is a Success [message #73415] Wed, 21 August 2013 23:05 UTC Go to next message
avatar gemsbridaljewellery  is currently offline gemsbridaljewellery
What do you think of the design Vote here if you Like. If you like it please share it on your facebook page.. Thank You[ 4 vote(s) ]
1.Love it 4 / 100%
2.Would share it with freinds 0 / 0%
3.Would change it 0 / 0%
4.Maybe 0 / 0%
This is our first printed ring in Gold Plated Brass. It came out great!!!! Thank You Shapeways...
Razz
index.php?t=getfile&id=38933&private=0index.php?t=getfile&id=38934&private=0
  • Attachment: 1-pc3 (1).JPG
    (Size: 160.12KB, Downloaded 427 time(s))
  • Attachment: 1-pc3 (3).JPG
    (Size: 164.77KB, Downloaded 420 time(s))
[Updated on: Wed, 21 August 2013 23:07 UTC]
Re: My first Gold Plated Brass Ring is a Success [message #73498 is a reply to message #73415 ] Thu, 22 August 2013 17:15 UTC Go to previous messageGo to next message
avatar MichaelMueller  is currently offline MichaelMueller
nice work!
Michael Mueller
www.pookas.de
Re: My first Gold Plated Brass Ring is a Success [message #73732 is a reply to message #73498 ] Tue, 27 August 2013 11:21 UTC Go to previous messageGo to next message
avatar Vidalcris  is currently offline Vidalcris
Very nice result & Design Wink
Re: My first Gold Plated Brass Ring is a Success [message #74234 is a reply to message #73415 ] Thu, 05 September 2013 09:44 UTC Go to previous messageGo to next message
avatar Designsoul  is currently offline Designsoul
Nice work! I recently printed a cufflink in GPB, it seems to be a great material. I was wondering if you have worn these rings over an extended period of time already. Does the gold plating wear off at some point? I'm asking because I would also like to sell some 3d printed jewelry, it would be great if we could share results.
www.designsoul.nl
Re: My first Gold Plated Brass Ring is a Success [message #74262 is a reply to message #74234 ] Thu, 05 September 2013 15:09 UTC Go to previous messageGo to next message
Thank you for your interest.
No I have not worn this ring. Have no idea how the gold plating lasts. We use these rings as master models to make rubber moulds, from the rubber we make wax models for direct lost wax casting into gold, silver and other metals. We are looking more for good detail and finish for our rubber moulds. I hope this helps in some way.
Thank you again for your comment.
Re: My first Gold Plated Brass Ring is a Success [message #74304 is a reply to message #74262 ] Thu, 05 September 2013 20:49 UTC Go to previous messageGo to next message
hi, thank you for the response. I can understand that for very exclusive pieces the customer will prefer a solid golden ring, but it leaves me curious to ask for your opinion as a jewelry designer, do you think this would be a suitable material to directly create jewelry out of, or are there other reasons not to do this?
By the way, your store includes some gorgeous pieces, I will keep it in mind in case I ever get married Smile
www.designsoul.nl
Re: My first Gold Plated Brass Ring is a Success [message #74360 is a reply to message #74304 ] Fri, 06 September 2013 19:04 UTC Go to previous messageGo to next message
Hi:
1. is this a good material to make jewellery from? Why not.
2. Will it wear well. It will always look gold even when the plating wears off. The brass may turn green over time where the gold plating has worn off because of skin acids affecting the brass. It should not be worn into a pool or hot tub. The chlorine and chemicals will effect any open brass areas where the plating has come off.
3. If you plan on wearing the item everyday. GOLD is the way to go.... Consider buying the item in FUD and having a jeweller cast or take a rubber mould from it, to reproduce the item in at least 10kt gold. Then the potential for green colour and base metal skin reactions will be removed.
Hope this is of some help in your consideration of materials.
Always consider how you are going to wear the item.
If everyday is the plan you have to consider the material of construction to make sure it will withstand the abuse of everyday life....
Re: My first Gold Plated Brass Ring is a Success [message #74362 is a reply to message #74360 ] Fri, 06 September 2013 19:07 UTC Go to previous messageGo to next message
Thank you, that is very helpful!
www.designsoul.nl
Re: My first Gold Plated Brass Ring is a Success [message #74539 is a reply to message #73415 ] Wed, 11 September 2013 05:20 UTC Go to previous messageGo to next message
avatar maskadelic  is currently offline maskadelic
Wow! what a lovely finish!
Re: My first Gold Plated Brass Ring is a Success [message #75007 is a reply to message #73415 ] Wed, 18 September 2013 15:38 UTC Go to previous messageGo to next message
Wow the brass looks great in that design! Be sure to tag it "bridal" and "weddings" so people can find it!
Community Manager | Shapeways
Re: My first Gold Plated Brass Ring is a Success [message #75254 is a reply to message #73415 ] Sun, 22 September 2013 20:08 UTC Go to previous message
I agree with gemsbridal here, although there is a nickel plate under the gold. The original plated stainless steel I do not use for rings anymore - the gold does indeed wear off. I have no idea how the new plated brass will stand up.
Previous Topic:Well printed bracelet!
Next Topic:Little tiny chair
