I will pay someone to make my polygon STL printable
I will pay someone to make my polygon STL printable [message #73084] Wed, 14 August 2013 23:56 UTC Go to next message
avatar nikkw0ng  is currently offline nikkw0ng
I have had NO luck with netfabb or similar edtiors to put my polygon together! I'm having an issue with a wall. That I can't put together. Can someone please help. I will pay you 10$. I don't think it should be that hard. I'm basically buying you a free meal! Let me know if anyone is interested. Thanks.
[Updated on: Wed, 14 August 2013 23:57 UTC]
Re: I will pay someone to make my polygon STL printable [message #73094 is a reply to message #73084 ] Thu, 15 August 2013 05:00 UTC Go to previous messageGo to next message
Ok 20$ Mad
Re: I will pay someone to make my polygon STL printable [message #73097 is a reply to message #73094 ] Thu, 15 August 2013 05:27 UTC Go to previous messageGo to next message
If you really want to pay someone, try posting in '3D Modeller needed'.
Otherwise, why not give a few more details and maybe someone will help for free!
What software are you using, what problems are you having? Can you share a file?
Re: I will pay someone to make my polygon STL printable [message #73101 is a reply to message #73097 ] Thu, 15 August 2013 08:15 UTC Go to previous messageGo to next message
Sorry! Here it is! There is a problem with one of the walls!!! I have been working on it for three days so frustrating Embarassed Mad
Re: I will pay someone to make my polygon STL printable [message #73103 is a reply to message #73101 ] Thu, 15 August 2013 11:52 UTC Go to previous messageGo to next message
well the handle looks good!
I ran the model through Netfabb Basic (which is free) and made a simple repair, which fixed some issues but not all.
The problems I have seen:
1. There are some stray vertices. There are some in the middle of the object which look like they should not be there, and at least one on an end face;
2. The meshes you have created are not watertight and non-manifold. To make a mesh to print each part must be a watertight mesh and the different meshes must overlap, they cannot just touch. Non-manifold means that a Vertex, an Edge or a Face of one mesh exactly coincides with one of these attributes of another mesh;
3. I'm guessing that your model was constructed in SketchUp, which unfortunately I know nothing about, but there are some very knowledgeable (and helpful) guys on the forums JACANT and Denali3ddesign among others. If you search out their posts on this subject I am sure you will find it helpful. The problem essentially seems to be that you have 'tiled' together elements without actually joining them.
I hope this helps a little bit,
good luck
Re: I will pay someone to make my polygon STL printable [message #73122 is a reply to message #73103 ] Thu, 15 August 2013 17:27 UTC Go to previous messageGo to next message
avatar Keymaker  is currently offline Keymaker
Shapeways Crew
i look at it but my program crashed while i was trying to figure it out Very Happy
But i believe i can fix it. (maybe it will be easier to just remodel it)
The only thing that limits us is our imagination.
Re: I will pay someone to make my polygon STL printable [message #73128 is a reply to message #73122 ] Thu, 15 August 2013 19:05 UTC Go to previous messageGo to next message
Whoever can fix it, I will definitely pay! 3d modeling is not for me!
Re: I will pay someone to make my polygon STL printable [message #73130 is a reply to message #73128 ] Thu, 15 August 2013 19:35 UTC Go to previous messageGo to next message
I will upgrade pay to 30$. I Would really like this done! Thanks!
Re: I will pay someone to make my polygon STL printable [message #73131 is a reply to message #73130 ] Thu, 15 August 2013 19:37 UTC Go to previous messageGo to next message
I will upgrade pay to 30$. I would really like this done. Confused Thanks!
Re: I will pay someone to make my polygon STL printable [message #73132 is a reply to message #73131 ] Thu, 15 August 2013 20:25 UTC Go to previous messageGo to next message
Shapeways Crew
Here you have it.
It took me just half an hour Very Happy
Re: I will pay someone to make my polygon STL printable [message #73133 is a reply to message #73132 ] Thu, 15 August 2013 20:32 UTC Go to previous message
Thank u SOOO much!!!! I've messaged you about payment thanks!!! Such a headache relieved Laughing
Previous Topic:Truck cab model needed
Next Topic:Gameboy DMG shells
