Hi There -
Here is another update on this subject. I decided to test out the feasibility of tapping further.
What I did was create 3 small Shapeways Stainless Steel (SS) pieces with a .339", .34375" (11/32) and .375" (12/32) diameters. I put a slight taper on each of these to make it easier to start the tap.
I also wanted to test a straight imperial (non-tapered) thread to see how that worked as well. For this test case I created a 50%, 25%, and 15% thread for a 1/4"-28 UNF machine screw. This equates to a diameter of .2281", .23905", and .24343" respectively. Each of these also had a slight taper to help with threading.
##Setup##
For my tapping equipment I used a standard ratcheting tap wrench and the following taps:
1/4"-28 Cobalt Steel (McMaster Part # 25215A61)
1/8"-27 NPT Cobalt Steel (Mcmaster Part # #2662A26)
I chose cobalt steel taps because they have a Rockwell hardness between C30 and C45 whereas Shapeway's Stainless has a hardness of 20-25 (
https://www.shapeways.com/rrstatic/material_docs/mds-stainle ss.pdf)
I also used a drill press to align the tap in the hole. Very similar to this process here:
https://www.youtube.com/watch?v=KmtbzL8YlxM. This was the first time I've used a drill press to align a tap and I found it did a very good job.
##Test Results##
I did the imperial 1/4"-28 (UNF) taps first starting with the 15% thread and moving up to the 15%.
All 3 threads were fairly easy. The easiest being the 15% thread and while the 50% was noticeably tougher although it was not what I would consider difficult. I was not concerned at any point the tap was at risk of breaking. As would be expected the thread on the 15% was barely noticeable. However, it would still mate with a machine screw and if screwed all the way in it would hold pretty well. The 50% created a really nice thread and the 25% was somewhere in the middle.
Next, I did the NPT taps starting with the 12/32" diameter and working my way to the smaller diameters. The 12/32" was very easy to do. It only produced a slight thread but it would mate with male NPT thread. The 11/32" was noticeably more difficult towards the bottom of thread. I stopped tapping with about 6-7 teeth still visible on the tap, which I believe is typical. This created a pretty well defined thread that mated very nicely. The .339", which is a standard "R" 1/8" NPT tap drill size was about the same difficulty as the 11/32".
##Closing Comments##
Based on these tests I would say that tapping Shapeways SS is definitely doable. I cannot say how much of an effect the cobalt steel taps or using the drill press for alignment had but I suspect they both helped significantly. I don't think the slightly tapered start had much of an impact but I also don't think this hurt things either.
While tapping I noticed that the chips were much finer that when you would typically see when tapping free machining metals. They were almost like large grains of sand. The material made a grating sound as it was tapped and even though the chips were smaller they still had to be broken (eg. back 1/4 turn for each turn forward). Also, the material did not get very hot like you would typically see when tapping something with a low heat transfer coefficient. I suspect this was due to the 40% bronze content.
