Home » Support » Suggestions & Feedback »
Material Requests / Suggestions
Material Requests / Suggestions [message #71689] Tue, 16 July 2013 20:49 UTC Go to next message
avatar instrumaker  is currently offline instrumaker
Material request: A strong and stainable wood composite.
Material improvement request: Detail plastic would be perfect if it could withstand higher temps (thinking about a product sitting in the current heat wave we're having), and if it came in polished finishes.
Re: Material Requests / Suggestions [message #71720 is a reply to message #71689 ] Wed, 17 July 2013 09:45 UTC Go to previous messageGo to next message
I think the only printers that currently support some kind of wood-like material are home printers; there are no industrial machines available that can do this, as far as I know.
If anyone knows of equipment for this kind of material, please share!
Re: Material Requests / Suggestions [message #71848 is a reply to message #71689 ] Fri, 19 July 2013 05:59 UTC Go to previous messageGo to next message
avatar Freakazoitt  is currently offline Freakazoitt
How about extremely fine detailed NON TRANSPARENT plastic?
Re: Material Requests / Suggestions [message #71985 is a reply to message #71720 ] Tue, 23 July 2013 09:31 UTC Go to previous messageGo to next message
avatar Daphne  is currently offline Daphne
Shapeways Crew
bartv wrote on Wed, 17 July 2013 09:45
I don't know what kind of printers they used:
http://www.emergingobjects.com/2012/01/13/wood/
The material looks quite interesting.
Re: Material Requests / Suggestions [message #71994 is a reply to message #71985 ] Tue, 23 July 2013 13:41 UTC Go to previous messageGo to next message
I would like a plastic that acts more like an injection-moulded plastic. I.e. non-porous, does not need sealing, will not become excessively dirty, possibly food safe.
Thx
Re: Material Requests / Suggestions [message #72597 is a reply to message #71994 ] Sun, 04 August 2013 03:07 UTC Go to previous messageGo to next message
avatar oahu_railway  is currently offline oahu_railway
I'm very excited by the new gold-plated brass. Not really for the gold plating, but for the brass support material. I'd love to be able to order products in brass, especially white brass (sometimes called German Silver or Nickel Silver).
Re: Material Requests / Suggestions [message #73258 is a reply to message #72597 ] Mon, 19 August 2013 05:07 UTC Go to previous messageGo to next message
avatar klambson  is currently offline klambson
I would like to voice support for a brass only material and forgo the gold plating or possibly stop at the nickel only just not interested in gold
Re: Material Requests / Suggestions [message #73291 is a reply to message #71689 ] Tue, 20 August 2013 02:35 UTC Go to previous messageGo to next message
avatar chromahands  is currently offline chromahands
im kinda new to shapeways, but i have had this odd issue with WSF materials:
why does shapeways offer black strong flexible, but not black strong flexible polished? especially when there are other dyed strong flexible polished available
Follow on Facebook: http://www.facebook.com/chromahands
Re: Material Requests / Suggestions [message #73295 is a reply to message #73291 ] Tue, 20 August 2013 03:22 UTC Go to previous messageGo to next message
chromahands wrote on Tue, 20 August 2013 02:35
Apparently the polishing makes it difficult to get a quality black finish with the dye.
Re: Material Requests / Suggestions [message #73374 is a reply to message #73295 ] Wed, 21 August 2013 15:29 UTC Go to previous messageGo to next message
avatar psantucci3  is currently offline psantucci3
Suggestion:
"Green" strong flexible Material.
Does The Color Pose Problems?
You Offer Other Colors.
Re: Material Requests / Suggestions [message #73378 is a reply to message #71689 ] Wed, 21 August 2013 15:36 UTC Go to previous messageGo to next message
its unfortunate that black cant go polished, how about gray then?
Re: Material Requests / Suggestions [message #73391 is a reply to message #73378 ] Wed, 21 August 2013 16:37 UTC Go to previous messageGo to next message
I would like to be able to print hollow models in ceramic and only the outside surface get glazed and therefore be charged only for the outside surface area.
Re: Material Requests / Suggestions [message #73410 is a reply to message #73391 ] Wed, 21 August 2013 21:12 UTC Go to previous messageGo to next message
Hollow models for ceramics are not a good idea. The heat of firing the ceramic will cause the part to blow open as the trapped air heats up and builds pressure - perhaps a more catastrophic bang than a pop.
Re: Material Requests / Suggestions [message #73444 is a reply to message #73410 ] Thu, 22 August 2013 08:10 UTC Go to previous messageGo to next message
There is no such thing as a hollow model at SW in the terms you are speaking of. If a model has no escape hole SW treats it as solid. If you wish to make a ceramic model with thickness *gt 15mm it MUST be hollow.
Re: Material Requests / Suggestions [message #73445 is a reply to message #73391 ] Thu, 22 August 2013 08:58 UTC Go to previous messageGo to next message
No problem if you limit yourself to Klein bottles Very Happy
Seriously, I suspect they apply the glaze by dipping the entire piece (probably the quickest and easiest method to achieve an even and complete cover)
Re: Material Requests / Suggestions [message #73460 is a reply to message #73445 ] Thu, 22 August 2013 11:34 UTC Go to previous messageGo to next message
I suspect you are right.
Well, let's put it another way - we are charged by surface area and the cause is supposed to be because of the glaze (although a cynical person might just put it down to another pricing model plucked from the air). If I create a hollow ceramic model with the required size escape hole and I want it glazed on the inside can it be guaranteed that the glaze will properly cover the inside surface? I think not.
So, if I want to create a ceramic version of my Heron (non-frog eating) I do not want it glazed on the inside (although if it is to whatever standard I don't care) and I certainly don't want to pay for that glaze. And I can't make it solid because it is too thick.
And, btw, I have asked this question before on the forums and in mails to service, but never received an official reply.
Re: Material Requests / Suggestions [message #73464 is a reply to message #73460 ] Thu, 22 August 2013 12:10 UTC Go to previous messageGo to next message
Suspect you would save on the glaze but pay more for the work required to paint or spray on the glaze.
If they just dunk it in the glaze pot and drain it as they pull it out, it should be glazed on the inside (and you can have a relatively unskilled worker do this quickly - saw this once at Zeller Keramik pottery, makers of the German classic "cock and hen" earthenware ).
Of course you would have two new failure paths for your model - (1) "escape hole too small, cannot glaze the inside" and (2) "would break during glazing" (with its belly full of non-froggy pond scum).
Lastly I guess you never got an official response from shapeways because the ceramics is done by a production partner.
Re: Material Requests / Suggestions [message #73466 is a reply to message #73464 ] Thu, 22 August 2013 12:31 UTC Go to previous messageGo to next message
Maybe, but their partner not mine, therefore still their responsibility.
They are very selective about what they reply to, imo. Viz the whole 'preventing rejections' thread which rumbled on for 6 months before anyone stuck their oar in.
Re: Material Requests / Suggestions [message #73501 is a reply to message #71689 ] Thu, 22 August 2013 17:38 UTC Go to previous messageGo to next message
avatar seriaforma  is currently offline seriaforma
How about paper? (mcor)
or cast aluminum?
or food safe silicone?
or more colors of the strong and flexible?
and I'd kind of like to see glass again.
Re: Material Requests / Suggestions [message #73575 is a reply to message #71689 ] Fri, 23 August 2013 18:22 UTC Go to previous messageGo to next message
Tacos!
Re: Material Requests / Suggestions [message #73579 is a reply to message #73575 ] Fri, 23 August 2013 18:41 UTC Go to previous messageGo to next message
Ugh.. Now, someone will think that the "Days for Delivery" should be Same-Day.
AND that a new material option will be "Spicy Sauce".
Re: Material Requests / Suggestions [message #75623 is a reply to message #71689 ] Fri, 27 September 2013 06:14 UTC Go to previous message
Knowledge Expert
Colored Glass ? Very Happy
numarul7 jewelry and design
Previous Topic:Save us time and money!
Next Topic:Please add a purchase order field to the payment section of checkout, invoices and packing
