Why the size differences between Edit and non-Edit mode?
Why the size differences between Edit and non-Edit mode? [message #71022] Fri, 05 July 2013 11:47 UTC Go to next message
I just had a ring printed for a client which was slightly different in width than he wanted.
This was probably due to shrinkage, which is fine, but then I got to looking at the
dimensions of the model. When in Edit mode the width (or height in Shapeways world)
shows as 3mm...
Original Bounds
In: 0.8 w x 0.8 d x 0.1 h Cm: 2.0 w x 2.0 d x 0.3 h
Oriented Bounds (used for determining printability)
But in non-Edit mode the width is 2.5mm.... Why is that? Simply rounding?
cm: 2.016 w x 2.016 d x 0.25 h in: 0.794 w x 0.794 d x 0.098 h
[Updated on: Fri, 05 July 2013 11:50 UTC]
Re: Why the size differences between Edit and non-Edit mode? [message #71024 is a reply to message #71022 ] Fri, 05 July 2013 12:03 UTC Go to previous messageGo to next message
Edit mode gives dimensions rounded to one decimal place, so 0.25 == 0.3 which indeed seems
less than ideal for small parts.
SW might want to fix this (surely just a format string issue - guess it might have been introduced
with the recent ad hoc addition of the density)
(BTW I just noticed that in your example, both "original" and "oriented" bounds appear to be identical.
Cut-and-paste error in your message?)
Re: Why the size differences between Edit and non-Edit mode? [message #71026 is a reply to message #71022 ] Fri, 05 July 2013 12:10 UTC Go to previous messageGo to next message
Figured it was something like that.... and no, I just double-checked, the original and oriented bounds are both exactly the same...
Re: Why the size differences between Edit and non-Edit mode? [message #71028 is a reply to message #71026 ] Fri, 05 July 2013 12:45 UTC Go to previous messageGo to next message
(Exactly the same due to the rounding... silly me. The 2.016 would reduce to 2.0 in the "abbreviated" format)
Re: Why the size differences between Edit and non-Edit mode? [message #71030 is a reply to message #71028 ] Fri, 05 July 2013 13:13 UTC Go to previous message
Thanks, I'll pass it on!
Previous Topic:Order cancelled
Next Topic:Need someone to teach me how to turn 2-D art into 3-D
