Home » Support » 3D Applications » Prperty for STL with LIGHTWAVE?
Prperty for STL with LIGHTWAVE? [message #294] Wed, 23 July 2008 15:06 UTC Go to next message
avatar akYip  is currently offline akYip
hi.
i'd like to know the setting of SHM_STL exporter with Lightwave3D.
It has "Binary" or "ASCII" in Type. Which should i use? Shocked
http://3dprintgames.com/
http://3dprintprice.com/
Re: Prperty for STL with LIGHTWAVE? [message #295 is a reply to message #294 ] Wed, 23 July 2008 16:57 UTC Go to previous messageGo to next message
Hi Akira,
We support both ASCII & binary encoded files.
Please let us know what your experiences are. You can sent any comments to service@shapeways.com.
Best regards,
Robert
Robert Schouwenburg
Re: Prperty for STL with LIGHTWAVE? [message #297 is a reply to message #295 ] Wed, 23 July 2008 17:22 UTC Go to previous messageGo to next message
hi Robert, ty for the response.
i created one simple box, divided into triangles in Lightwave3D.
After that, exported it with STL using SHM_STL exporter and uploaded to the site.
However i gotta e-mail says "The model could not be validated. "
What else should I do?
Re: Prperty for STL with LIGHTWAVE? [message #298 is a reply to message #294 ] Wed, 23 July 2008 17:33 UTC Go to previous messageGo to next message
a box is like this:)
http://bp0.blogger.com/_QqpC6Py3Fw0/SIdrB9RwTcI/AAAAAAAAACE/CGFoRXrZSmc/s320/shape.jpg
Re: Prperty for STL with LIGHTWAVE? [message #301 is a reply to message #298 ] Wed, 23 July 2008 20:22 UTC Go to previous messageGo to next message
Your box should be ok from the looks of it. Very Happy
Would you be so kind to sent the resulting STL file to service@shapeways.com?
I can then analyze the issue more thoroughly.
Robert
Robert Schouwenburg
Re: Prperty for STL with LIGHTWAVE? [message #305 is a reply to message #294 ] Thu, 24 July 2008 04:01 UTC Go to previous messageGo to next message
will send the file later. thanks! Very Happy
Re: Prperty for STL with LIGHTWAVE? [message #306 is a reply to message #305 ] Thu, 24 July 2008 07:19 UTC Go to previous messageGo to next message
Hi Akira,
it's probably the size of the model that's causing this problem. Our STL import is currently interpreting 1 unit as 1 meter, and that can easily exceed the maximum print volume of our printers.
Try scaling down your model by a factor of 100 or even 1000 and see it uploads correctly.
Re: Prperty for STL with LIGHTWAVE? [message #318 is a reply to message #305 ] Thu, 24 July 2008 15:15 UTC Go to previous messageGo to next message
I was just thinking. Can you check if the normals are pointing to the outside?
That could be a reason for the failure.
Best regards,
Robert
Robert Schouwenburg
Re: Prperty for STL with LIGHTWAVE? [message #412 is a reply to message #294 ] Tue, 29 July 2008 17:11 UTC Go to previous messageGo to next message
Finally i managed to upload my simple box model.
Creating a box with Lightwave3D and subdiv into triangles.
Then export it as a "OBJ" file.
Convert "OBJ" file to "STL" with MeshLab.
(i tryed "3ds" from Lightwave but it failed to open with MeshLab.)
That's all.
i haven't tested any complicated model yet, but hope this information will help Lightwave users.
ak
Re: Prperty for STL with LIGHTWAVE? [message #423 is a reply to message #412 ] Wed, 30 July 2008 10:35 UTC Go to previous messageGo to next message
Hi Akira,
was the triangulation required to get it uploaded? Our server should triangulate the mesh automatically - I'd be interested in hearing if it didn't
Re: Prperty for STL with LIGHTWAVE? [message #435 is a reply to message #294 ] Wed, 30 July 2008 19:36 UTC Go to previous messageGo to next message
i'd trianglated before uploding.
but i guess it's useful for beginners if server triangulate automatically.
Re: Prperty for STL with LIGHTWAVE? [message #437 is a reply to message #435 ] Thu, 31 July 2008 07:53 UTC Go to previous message
Hi Akira,
yes, that was my point Wink Our server *should* triangulate automatically, so I was wondering if you could get your file uploaded without triangulating it yourself.
Previous Topic:pro engineer user
Next Topic:Anyone successfully exporting from Solidworks?
