Weekend contest #17: Let us show you off!
Weekend contest #17: Let us show you off! [message #70681] Fri, 28 June 2013 20:18 UTC Go to next message
http://www.shapeways.com/blog/uploads/ben.PNG
For our booth at MakerFaire, we 3D printed our back wall. If you ignore Ben, Savannah, and R2D2 you can see them hanging in the background
For SIGGRAPH, and every show going forward, we would love our booth to have EVERY material represented on the wall, and each panel to be designed by our community.
So that's where you come in.
We are looking specifically for panels designed for Alumide and Elasto but are open to other materials like FUD and Steel too (we have enough WSF though!)
The restrictions are:
Size: 30cm x 30cm x the materials required thickness - (12" high x 12" wide) so about one foot square.
Holes: four holes, one in each corner minimum diameter 10mm - these are so we can connect them together as show in the picture
Complies with all material guidelines
Deadline is uploaded by Tuesday July 2nd.
Each Material will have it's own winner, and there can be multiple winners so multiple prizes of $25 Shapeways bucks are up for grabs!
index.php?t=getfile&id=35526&private=0
  • Attachment: kid.JPG
    (Size: 191.51KB, Downloaded 1403 time(s))
[Updated on: Fri, 28 June 2013 20:52 UTC] by Moderator
Re: Weekend contest #17: Let us show you off! [message #70694 is a reply to message #70681 ] Fri, 28 June 2013 21:47 UTC Go to previous messageGo to next message
avatar skazm  is currently offline skazm
Shapeways Crew
Count me in, after Shabbos! Woo!
http://facebook.com/artisanjudaica
Re: Weekend contest #17: Let us show you off! [message #70697 is a reply to message #70694 ] Fri, 28 June 2013 21:53 UTC Go to previous messageGo to next message
avatar trishycakes  is currently offline trishycakes
I am all for this! Count me in as well.
Re: Weekend contest #17: Let us show you off! [message #70699 is a reply to message #70681 ] Fri, 28 June 2013 22:14 UTC Go to previous messageGo to next message
avatar ideakid  is currently offline ideakid
I'm in!
Re: Weekend contest #17: Let us show you off! [message #70702 is a reply to message #70681 ] Fri, 28 June 2013 23:18 UTC Go to previous messageGo to next message
avatar joabaldwin  is currently offline joabaldwin
Here is my submission! A panel of reptiles that would be great in elasto, the thin wire lizards would expand and allow you to bend the thing all over. I made the wires a bit over 2mm so it should stand the weight.
index.php?t=getfile&id=35527&private=0
And here's the link for the model: http://shpws.me/ok6W
Re: Weekend contest #17: Let us show you off! [message #70705 is a reply to message #70681 ] Sat, 29 June 2013 04:29 UTC Go to previous messageGo to next message
avatar MasterOfScience  is currently offline MasterOfScience
Am I reading the size requirements right? They seem to specify a 300 x 300 mm square, but Alumide has a max bounding box of 230x180x310mm according to the design specifications. Can the square be smaller than 300 mm, and if so, how small?
Everything can be improved.
Re: Weekend contest #17: Let us show you off! [message #70708 is a reply to message #70705 ] Sat, 29 June 2013 06:45 UTC Go to previous messageGo to next message
The size above of one square foot is not quite right. Michael did say "Complies with all Material Guidelines", which would include limiting the model to the max build volume available for the various printers.
For example, FUD needs to be limited (for this contest) to around 120x120mm
For Alumide, I'd stick to 220x220mm or so
Unless of course, if you were design your object at 150x150mm and expect to connect 4 of them together to make up the 300x300mm size.
Re: Weekend contest #17: Let us show you off! [message #70709 is a reply to message #70708 ] Sat, 29 June 2013 06:52 UTC Go to previous messageGo to next message
I just had a thought... someone ought to try the Shapeways QR code.
Re: Weekend contest #17: Let us show you off! [message #70720 is a reply to message #70709 ] Sat, 29 June 2013 20:01 UTC Go to previous messageGo to next message
avatar Daphne  is currently offline Daphne
Shapeways Crew
I made a panel based on a bracelet I designed. The panel exist of two lines and 27x27 little hearts with rings on them to connect to each other.
It is 300x292 mm, with wires of 1 mm. It's designed for elasto, so you could really stretch it.
My laptop didn't liked it all. The stl file is over 500 mb, and I saved it in the lowest setting.
index.php?t=getfile&id=35594&private=0
Re: Weekend contest #17: Let us show you off! [message #70721 is a reply to message #70681 ] Sat, 29 June 2013 20:02 UTC Go to previous messageGo to next message
avatar vertigopolka  is currently offline vertigopolka
I've designed woven panels at 150 mm for Alumide and at 300 mm for Elasto Plastic. Although the 150 mm panel could be printed in a variety of materials and hung together to form the full size panel. It was difficult keeping it under 1 million facets. Smile
model pages:
Squiggleweave Panel-300mm
Squiggleweave Panel-150mm
index.php?t=getfile&id=35593&private=0
@vertigopolka
http://www.vertigopolka.com
Re: Weekend contest #17: Let us show you off! [message #70761 is a reply to message #70681 ] Mon, 01 July 2013 13:42 UTC Go to previous messageGo to next message
Awesome designs so far! Didn't even think about the max dimensions of the materials Confused I'm sure we can glue something together Wink
Re: Weekend contest #17: Let us show you off! [message #70779 is a reply to message #70681 ] Mon, 01 July 2013 18:21 UTC Go to previous messageGo to next message
avatar fx2  is currently offline fx2
The first one is designed to be printed in alumide. it's 30x30 cm, but thanks to the hinge it fits into the Alumide printer max printing volume.
http://www.shapeways.com/model/1184262/alumide-panel-30x30.h tml
index.php?t=getfile&id=35664&private=0 More pics on the model page...
[Updated on: Mon, 01 July 2013 18:24 UTC]
Re: Weekend contest #17: Let us show you off! [message #70780 is a reply to message #70681 ] Mon, 01 July 2013 18:24 UTC Go to previous messageGo to next message
My second entry is for Stainless Steel (more precisely Antique Bronze Matte):
It shows the nice things that can be printed in metal... 30x30 cm size.
http://www.shapeways.com/model/1186308/stainless-panel-30x30 .html
index.php?t=getfile&id=35665&private=0
[Updated on: Mon, 01 July 2013 18:25 UTC]
Re: Weekend contest #17: Let us show you off! [message #70786 is a reply to message #70681 ] Mon, 01 July 2013 20:40 UTC Go to previous messageGo to next message
The elastoplastic seems to call to me for some reason. Probably because I do masks and things, but I made my wall panel a filigree panel that also can double as a mask when stretched over a face or mannequin form.
http://www.shapeways.com/model/1186700/quot-elasto-mask-quot -elasto-plastic-panel.html <--The model
http://imageshack.us/a/img153/1139/o7ae.jpg
http://imageshack.us/a/img708/4940/k0p6.jpg
http://imageshack.us/a/img600/8477/zgh5.jpg
*note* I would not recommend eating it like my model here seems to be doing....
[Updated on: Mon, 01 July 2013 20:43 UTC]
Re: Weekend contest #17: Let us show you off! [message #70790 is a reply to message #70681 ] Mon, 01 July 2013 20:52 UTC Go to previous messageGo to next message
wow!! these are awesome everyone!!
Re: Weekend contest #17: Let us show you off! [message #70796 is a reply to message #70681 ] Tue, 02 July 2013 00:30 UTC Go to previous messageGo to next message
avatar GeoBling  is currently offline GeoBling
We have a few geographical submission Smile
Mt Rainier:
30 x 30: http://www.shapeways.com/model/1185531/mt-rainier-30cm-x-30c m-panel.html
15 x 15: http://www.shapeways.com/model/1185527/mt-rainier-15cm-x-15c m-panel.html
And LA, since that's where the booth will go next for SIGGRAPH:
30 x 30: http://www.shapeways.com/model/1185524/greate-la-area-30cm-x -30cm-panel.html
15 x 15: http://www.shapeways.com/model/1185522/greate-la-area-15cm-x -15cm-panel.html
http://images1.sw-cdn.net/model/picture/674x501_1185531_1107856_1372661719.jpg
http://images1.sw-cdn.net/model/picture/674x501_1185524_1107846_1372661403.jpg
If you like another place more, or want a new one for ever conference/exhibition with the location of the show, let us know. We can generate these pretty quickly.
The Society for Printable Geography
www.printablegeography.com
Re: Weekend contest #17: Let us show you off! [message #70798 is a reply to message #70681 ] Tue, 02 July 2013 00:34 UTC Go to previous messageGo to next message
avatar draw  is currently offline draw
I have two designs. I call the first one the maze. You could look at it from either side but looking at the convex side first makes you wonder what's on the other side. Why is there a segment that is out of place? You are compelled to look at the other side!
http://images1.sw-cdn.net/model/picture/674x501_1187085_1109677_1372722477.jpg
http://shpws.me/ole3
My other design is based on a vent vane I designed to fix cracked ones on a house but at $26 it was still too expensive. (Speaking of which you guys could use a cheaper industrial quality WSF process that can have slight defects or gross colors if you recycle old dirty powders.) This panel has little handles on the three vent vanes so people can look inside. If you want a really neat panel get a standard 12VDC 120mm computer muffin fan and screw it on the back (you need to drill your own holes for your fan), Then hook it up to a switch or a periodic timer that cycles the power on and off from a battery or power supply to make the vanes open up in the breeze from the fan. There is an internal screen in the air flow path to protect little fingers from the fan if stuck in past the vanes. You need to put a screen on the back of the muffin fan if it is exposed. Instead of a fan the back side of the panel could be redesigned to connect to a vent hose but that would be another project. This thing is designed to be industrial trade show quality with 0.1 inch thick walls for the large panel parts. The vane peg holes are oversized about 0.38 mm around the pegs which may or may not allow this panel to be printed in one piece. I've never done that before. It might be a good idea to print the vanes separately from the main panel and then install them afterwards. Good luck if you print this beast!
http://images1.sw-cdn.net/model/picture/674x501_1187081_1109673_1372722309.jpg
http://shpws.me/oleb
Re: Weekend contest #17: Let us show you off! [message #70801 is a reply to message #70681 ] Tue, 02 July 2013 02:54 UTC Go to previous messageGo to next message
avatar sorhain  is currently offline sorhain
I designed two different panels for this.
The first is for Alumide. Designed and sized to be printed 4 times to be one pannel.
It has the Shapeways QR Code in the center of a Sun Burst.
Link to the model
http://www.shapeways.com/model/1187237/shapeways-qr-code-bur st-alumide.html?li=modelEdit
index.php?t=getfile&id=35693&private=0
  • Attachment: qr2.jpg
    (Size: 72.28KB, Downloaded 960 time(s))
www.corinnehansen.com sorhain@gmail.com
Re: Weekend contest #17: Let us show you off! [message #70802 is a reply to message #70681 ] Tue, 02 July 2013 02:55 UTC Go to previous messageGo to next message
The second panel I designed is for Elasto. It was also designed and sized to be printed 4 times to be one pannel.
There a thin .93 mm supported wires for maximum flexibility.
Link to the model
http://www.shapeways.com/model/1187243/shapeways-elasto.html ?li=modelEdit
index.php?t=getfile&id=35694&private=0
  • Attachment: wed2.jpg
    (Size: 72.81KB, Downloaded 967 time(s))
Re: Weekend contest #17: Let us show you off! [message #70806 is a reply to message #70681 ] Tue, 02 July 2013 04:15 UTC Go to previous messageGo to next message
My design partner and I are submitting the "Spiderweb" in either Elasto or Steel:
http://shpws.me/okEb
http://images1.sw-cdn.net/model/picture/674x501_1184279_1106421_1372737957.jpg
Re: Weekend contest #17: Let us show you off! [message #70807 is a reply to message #70681 ] Tue, 02 July 2013 04:22 UTC Go to previous messageGo to next message
Well, I see I wasn't the only one to think of a spider web, but I think mine's nicer, so I'm posting it anyway. I think it should be very tactile to play with (for the Elasto Plastic).
<a href=" http://www.shapeways.com/model/1187403/spiderwebtilestep5.ht ml?li=my-models&key=0e93435428bf306af5d136c8bd36746c" target="_blank"> http://www.shapeways.com/model/1187403/spiderwebtilestep5.ht ml?li=my-models&key=0e93435428bf306af5d136c8bd36746c</a>
Gillian.
[Updated on: Tue, 02 July 2013 05:18 UTC]
Re: Weekend contest #17: Let us show you off! [message #70819 is a reply to message #70681 ] Tue, 02 July 2013 10:20 UTC Go to previous messageGo to next message
avatar Tahereh  is currently offline Tahereh
My entry is for Alumide.
I used Shapeways logo ( the star ) in my design.
http://oi40.tinypic.com/2qnwo5g.jpg
http://oi40.tinypic.com/2niqvxy.jpg
http://oi40.tinypic.com/30lkznd.jpg
[Updated on: Tue, 02 July 2013 23:40 UTC]
Re: Weekend contest #17: Let us show you off! [message #70833 is a reply to message #70681 ] Tue, 02 July 2013 15:39 UTC Go to previous messageGo to next message
avatar andresroppa  is currently offline andresroppa
Hi, my name is Andres Roppa from Uruguay and I have been collaborating with Paul Tucker, a "wood artist" from the US, but to better describe what he is involved in check out his facebook page, it´s amazing. I have been developing some models for printing that Paul is using on a project of his ... while at this he suggested a Ransom Spiral panel for this occasion.
https://www.facebook.com/MoorishFretwork?fref=ts
The panel was designed and uploaded for white polyamide according to a wood model made by Paul, it´s hollowed out and shows the intricacies of the Ransom Spiral and how the shape works when woven together... I hope you like it.
Andres Roppa | Product Designer
www.ANDRESROPPA.com | andresroppa@gmail.com
index.php?t=getfile&id=35785&private=0
Digital model development for 3D Printing
Re: Weekend contest #17: Let us show you off! [message #70834 is a reply to message #70681 ] Tue, 02 July 2013 15:57 UTC Go to previous messageGo to next message
I made a woven pattern entry for the elasto material. The pattern looks different on the front and back. I've also included my SolidWorks source file Smile Feel free to use as you please.
http://www.shapeways.com/model/1188272/panel.html?li=my-mode ls&key=9b6932d946d600015fb38de83c2bd709
http://images1.sw-cdn.net/model/picture/674x501_1188272_1111070_1372780273.jpg
http://images1.sw-cdn.net/model/picture/674x501_1188272_1111071_1372780277.jpg
  • Attachment: panel.SLDPRT
    (Size: 15.90MB, Downloaded 82 time(s))
[Updated on: Tue, 02 July 2013 16:02 UTC]
Re: Weekend contest #17: Let us show you off! [message #70835 is a reply to message #70833 ] Tue, 02 July 2013 17:01 UTC Go to previous messageGo to next message
Shapeways Crew
I made my heart frame also available for alumide. This time it's 133x146 mm, so 4 panels could be made into one. The file isn't over 500 mb, but with 70 mb still too big to upload.
index.php?t=getfile&id=35793&private=0
Re: Weekend contest #17: Let us show you off! [message #70840 is a reply to message #70681 ] Tue, 02 July 2013 20:02 UTC Go to previous messageGo to next message
avatar Wahtah  is currently offline Wahtah
Another woven panel, showing the infinite possibilities of 3D printing. The colors are just to show the 18 individual components making up the panel. The wires are 2mm across.
It's about 30 by 30 cm as in the original instructions. Making a smaller version for alumide would not be a problem, but I would love to see it in flexible.
The model has 951280 faces and is pretty expensive but for once I don't care about that Smile
Link to model: http://shpws.me/olA3
index.php?t=getfile&id=35794&private=0
  • Attachment: Capture2.JPG
    (Size: 140.41KB, Downloaded 749 time(s))
[Updated on: Tue, 02 July 2013 20:34 UTC]
Re: Weekend contest #17: Let us show you off! [message #70841 is a reply to message #70840 ] Tue, 02 July 2013 20:06 UTC Go to previous messageGo to next message
Wahtah, that is a fantastic use for this. Nice work.
Re: Weekend contest #17: Let us show you off! [message #70847 is a reply to message #70841 ] Tue, 02 July 2013 21:26 UTC Go to previous messageGo to next message
Thanks joabaldwin!
Quickly while it's still tuesday... This one is made of interlocked rings, the cross section of the wire is oval, 2mm high and 4mm wide. If you look closely the outside of the panel and the inside of the holes have a single wire running around them. The fact that the holes are almost shapeway-logo shaped is pure coincidence...
Made for flexible, it consists of 308 separate components, 474400 faces in total.
http://shpws.me/olDd
index.php?t=getfile&id=35796&private=0
Re: Weekend contest #17: Let us show you off! [message #70849 is a reply to message #70847 ] Tue, 02 July 2013 22:12 UTC Go to previous messageGo to next message
Gah. Messhieurs are meshing up de upload times with your creashions. Shocked
Re: Weekend contest #17: Let us show you off! [message #70857 is a reply to message #70849 ] Wed, 03 July 2013 02:05 UTC Go to previous messageGo to next message
DANGGG!!! Great work guys! Surprised
I would have entered one of my digital fabrics, but I think you guys already got me beat! Very Happy
I'm glad I'm not the one who has to pick a winner. They are all winners in my opinion!
I think Tahereh_Shahidi has a slight advantage though given that they thought to use a part of the Shapeways logo. Very Happy
As for something I would put in my house, I kind of like andresroppa's design. Smile
Good luck trying to decide on a winner! HAHAHA!! Laughing
Patterns For CNC
Re: Weekend contest #17: Let us show you off! [message #71049 is a reply to message #70681 ] Fri, 05 July 2013 18:55 UTC Go to previous messageGo to next message
Apologies for the delay everyone, and happy 4th to all in the USA Smile
I would love to print all of these, so I may be giving out a few prizes here Wink
Re: Weekend contest #17: Let us show you off! [message #71118 is a reply to message #71049 ] Sun, 07 July 2013 02:41 UTC Go to previous messageGo to next message
Shapeways Crew
I started one but saw I was pastdeadline, should I u/l it anyway?
Re: Weekend contest #17: Let us show you off! [message #71168 is a reply to message #71118 ] Mon, 08 July 2013 12:48 UTC Go to previous messageGo to next message
skazm wrote on Sun, 07 July 2013 02:41
We do lots of shows, so please do share, and maybe we'll be able to consider it for future events!
Re: Weekend contest #17: Let us show you off! [message #71280 is a reply to message #70681 ] Tue, 09 July 2013 16:56 UTC Go to previous messageGo to next message
Ok guys, these are FANTASTIC and rather than pick one winner, I'm picking (almost) ALL OF THEM! YAY!
Laughing
Every model that I can get printed is going to SIGGRAPH. Look our for an email in your inbox later today with your gift code to:
Wahtah - Elasto weave
Master of Science - Elasto
Tahereh - Alumide sparks
Sorhain - Alumide QR code
GHP - Alumide Spiderweb
Draw - Elasto maze
Geobling - WSF/Alumide of LA
Trishycakes - Elasto face
fx2 - Alumide hinges
Vertigopolka - WSF squiggle
Joabaldwin - Elasto tesselation
Almost there...
Daphne - I love this, but I can't make it upload. If you can reduce the size (maybe by reducing the density of the curvy bits, so they are not so tightly packed) and upload it, I'd be happy to print it too.
AndresRopa - if you can upload this model, we could bring it as well. What material do you want to print it in?
Congratulations everyone! I'll be posting LOADS of photos from the booth once they are all printed and hung. I cant WAIT to see it!!
[Updated on: Tue, 09 July 2013 17:03 UTC]
Re: Weekend contest #17: Let us show you off! [message #71285 is a reply to message #71280 ] Tue, 09 July 2013 17:04 UTC Go to previous messageGo to next message
This is awesome! Thanks for the opportunity Natalia! Can't wait for the pictures.
Re: Weekend contest #17: Let us show you off! [message #71289 is a reply to message #71285 ] Tue, 09 July 2013 17:12 UTC Go to previous messageGo to next message
I think you guys should wear 3D printed shoes and clothes to the show too! HAHAHA! Laughing
Patterns For CNC
Re: Weekend contest #17: Let us show you off! [message #71290 is a reply to message #70681 ] Tue, 09 July 2013 17:18 UTC Go to previous messageGo to next message
That's really great ! I'm really interested to see the pictures of the booth, too. Smile
[Updated on: Tue, 09 July 2013 17:19 UTC]
Re: Weekend contest #17: Let us show you off! [message #71355 is a reply to message #71280 ] Wed, 10 July 2013 15:13 UTC Go to previous messageGo to next message
Sounds great Natalia!
I´ve already uploaded the file, but I don´t know if that is enough for you to print. I think the only material that will work for this is WSF.
Looking forward to seeing these panels.
thanks!
andres
Re: Weekend contest #17: Let us show you off! [message #71455 is a reply to message #70681 ] Thu, 11 July 2013 16:20 UTC Go to previous messageGo to next message
Wow! Thank you very much! I am really excited to see how the designs turn out! I can't wait to see the pictures!
Thank you again! Smile
Re: Weekend contest #17: Let us show you off! [message #71471 is a reply to message #71455 ] Thu, 11 July 2013 19:54 UTC Go to previous messageGo to previous message
I missed this one, interesting idea... for a follow up, if you get 20 people to make triangular panels, then you could combine them together to make an icosahedron to hang from the ceiling!
Pages (2): [1  2    »]
Previous Topic:Necessary Roughness necklace
Next Topic:Weekend contest #19: Here Comes The Bride!
