Home » Developers » Shapeways API »
GET Materials/v1
GET Materials/v1 [message #70448] Tue, 25 June 2013 10:02 UTC Go to next message
avatar Rafferty  is currently offline Rafferty
If I try and call
http://api.shapeways.com/materials/v1
I get a page of documentation back for the API (which is fine).
How do I actually get some values back?
Do I need to pass my OAuth credentials as URL parameters. If so, what format should the URL take (I've already tried, and got 401 errors).
Thanks in advance
Re: GET Materials/v1 [message #70469 is a reply to message #70448 ] Tue, 25 June 2013 13:20 UTC Go to previous messageGo to next message
avatar hans_lambermont  is currently offline hans_lambermont
Hi Rafferty,
When you access the API without OAuth credentials you connect to the JSON API discovery system.
To get started with the API and OAuth please have a look at http://developers.shapeways.com/getting-started?li=dh_gs
regards,
Hans Lambermont
Re: GET Materials/v1 [message #70476 is a reply to message #70448 ] Tue, 25 June 2013 14:42 UTC Go to previous messageGo to next message
avatar ProfessorBeekums  is currently offline ProfessorBeekums
Sending oauth credentials as URL parameters will cause 401 errors. They need to be sent in the authorization header.
Re: GET Materials/v1 [message #70829 is a reply to message #70476 ] Tue, 02 July 2013 13:04 UTC Go to previous messageGo to next message
Thanks for your response.
I also get "(401) Unauthorised" when I send the oAuth in the header (that's why I was trying the URL instead). My HTTP request looks something like:
GET http://api.shapeways.com/materials/v1 HTTP/1.1
Authorization: OAuth oauth_consumer_key="???",oauth_nonce="???",oauth_signature= "???",oauth_signature_method="HMAC-SHA1",oauth_timestamp= "1372769703",oauth_version="1.0"
Host: api.shapeways.com
Connection: Keep-Alive
Thanks in advance
Rafferty
Re: GET Materials/v1 [message #70899 is a reply to message #70829 ] Wed, 03 July 2013 15:21 UTC Go to previous messageGo to next message
Are you getting a json error message with the 401? We send those so that you'll know why the 401 was sent.
Re: GET Materials/v1 [message #71041 is a reply to message #70899 ] Fri, 05 July 2013 15:37 UTC Go to previous message
Yeah! Thanks. The clue was in the JSON.
Previous Topic:Ring Creator: Shapeway's app on the API
Next Topic:redirect loop when trying to manage apps
